Configurate Dynamic DNS for dynv6
I made the configuration of Dynamic DNS as per the spec in dynv6.com as below:
vyos@vyos# show service dns dynamic
name DDNS-dynv6 {
address {
interface eth0
host-name zionpath.eion.design
ip-version ipv6
password xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
protocol dyndns2
server dynv6.com
username none
But looks not working properly, IP status is noconnect.
vyos@vyos:~$ show dns dynamic status
Hostname IPv4 address IPv4 status IPv6 address IPv6 status Last update
zionpath.eion.design noconnect noconnect 1970-01-01 08:00:00
Would someone can review my configuration to see if anything I missed or incorrect?
My Vyos version is 1.5-rolling-202412160007 and interface configuration as below:
vyos@vyos:~$ show int eth
eth0 192.168.100.106/24 u/u WAN0
2409:8a1e:70dd:9a90::3/128
eth1 - u/D WAN1
eth2 2409:8a1e:70dd:9a91::f000/64 u/D DMZ
eth3 192.168.200.250/24 u/u LAN
fd00::f000/112
Thanks in advance.
Hello @Nicolas.Li,
I resurrected a test dynv6 account to test it. Looks like, the following configuration works for me:
vyos@test-1218# show service dns dynamic name dynv6
address {
    interface eth3
host-name myhost.dynv6.net
ip-version both
password xxxxx
protocol dyndns2
server dynv6.com
username none
vyos@test-1218# run show dns dynamic status
myhost.dynv6.net         11.222.333.444  good           2001:...:...:...                       good           2024-12-18 23:47:19
Could you please take a look at the log to see if anything abnormal shows up? You can try something like show log dns dynamic or monitor log dns dynamic.
Thanks!
I think this hostname is incorrect
Thanks a lot!
it’s strange to me.
I deleted ddclient.cache and restart dns dynamic, then I got log below, please help to review it.
vyos@vyos:~$ show log dns dynamic
Dec 19 16:06:32 systemd[1]: Starting ddclient.service - Update dynamic domain name service entries…
Dec 19 16:06:32 systemd[1]: Started ddclient.service - Update dynamic domain name service entries.
Dec 19 16:42:51 systemd[1]: Stopping ddclient.service - Update dynamic domain name service entries…
Dec 19 16:42:51 systemd[1]: ddclient.service: Deactivated successfully.
Dec 19 16:42:51 systemd[1]: Stopped ddclient.service - Update dynamic domain name service entries.
Dec 19 16:42:51 systemd[1]: Starting ddclient.service - Update dynamic domain name service entries…
Dec 19 16:42:51 systemd[1]: Started ddclient.service - Update dynamic domain name service entries.
Dec 19 16:42:51 ddclient[5031]: WARNING: curl cannot connect to https://dynv6.com using IPv0
Dec 19 16:42:51 ddclient[5032]: FAILED: updating zionpath.eion.design: Could not connect to dynv6.com.
vyos@vyos:~$
further checked and identified it’s a DNS issue.
set system name-server 8.8.8.8 makes the issue resolved.
Thanks all
