Now if I shutdown primary link. Tunnel goes down for about a minute or so and even if I other link is up ip bgp does not show the routes received. Almost after 1-2 minute BGP routes appears and the traffic fails over.
So any idea what should be the ideal configuration for fast convergence and minimal packet loss?
Hmm…those are pretty new to me. Any existing config available or template would help me to understand much faster.
Any way I am researching on my own as well.
Any idea if we can achieve multipath with wireguard+BFD+BGP? I have not actually started implementing it but creating a topology hence wanted to ensure if multiple links can be achieved using this solution?
Unfortunately, I don’t have the experience with VyOS to provide instructions, but BFD works in conjunction with a routing protocol to detect a path outage faster than a routing protocol normally would. For example, BGP may take 60sec to time out, while BFD might poll more quickly, like once every 100ms and take a path down after 5 missed bfd replies before BGP detects the outage. BFD doesn’t replace any routing protocol, it just works along side it to detect when a path has gone down quickly.
I think the wireguard suggestion, is just because it’s easier than IPSec. I’ve spent many moons troubleshooting IPSec and very little to show for it. Even after years I still get stumped by issues and get frustrated with it. Wireguard has a lot of positive attributes about it. It’s simpler to set up and operate, it deals with packet fragmentation well, and it performs well on standard hardware.
R1
From $mode
generate wireguard keypair
set interfaces ethernet eth0 address '192.168.47.20/24'
set interfaces ethernet eth0 hw-id '00:0c:29:d4:6e:9e'
set interfaces ethernet eth0 smp-affinity 'auto'
set interfaces ethernet eth1 address '10.30.30.20/24'
set interfaces ethernet eth1 hw-id '00:0c:29:d4:6e:a8'
set interfaces ethernet eth1 smp-affinity 'auto'
set interfaces ethernet eth2 address '10.10.20.20/24'
set interfaces ethernet eth2 duplex 'auto'
set interfaces ethernet eth2 hw-id '00:0c:29:d4:6e:b2'
set interfaces ethernet eth2 smp-affinity 'auto'
set interfaces ethernet eth2 speed 'auto'
set interfaces loopback lo
set interfaces wireguard wg01 address '10.44.44.1/30'
set interfaces wireguard wg01 peer tun-wg02 allowed-ips '192.168.40.0/24'
set interfaces wireguard wg01 peer tun-wg02 allowed-ips '10.44.44.2/32'
set interfaces wireguard wg01 peer tun-wg02 endpoint '192.168.47.40:51820'
set interfaces wireguard wg01 peer tun-wg02 pubkey <COPY THAT PUBKEY>
set interfaces wireguard wg01 port '51820'
set interfaces wireguard wg02 address '10.88.88.1/30'
set interfaces wireguard wg02 peer tun-wg04 allowed-ips '192.168.40.0/24'
set interfaces wireguard wg02 peer tun-wg04 endpoint '10.30.30.40:51840'
set interfaces wireguard wg02 peer tun-wg04 pubkey <COPY THAT PUBKEY>
set interfaces wireguard wg02 port '51840'
set protocols bgp 65001 address-family ipv4-unicast network 10.10.20.0/24
set protocols bgp 65001 neighbor 10.44.44.2 remote-as '65002'
set protocols bgp 65001 neighbor 10.44.44.2 update-source '10.44.44.1'
set protocols bgp 65001 timers holdtime '6'
set protocols bgp 65001 timers keepalive '2'
set protocols static
set service ssh
set system console device ttyS0 speed '9600'
set system host-name 'R1'
set system login user vyos level 'admin'
AND R2
$ generate wireguard keypair
set interfaces ethernet eth0 address '192.168.47.40/24'
set interfaces ethernet eth0 hw-id '00:0c:29:b5:16:c7'
set interfaces ethernet eth1 address '192.168.40.40/24'
set interfaces ethernet eth1 hw-id '00:0c:29:b5:16:d1'
set interfaces ethernet eth2 address '10.30.30.40/24'
set interfaces ethernet eth2 hw-id '00:0c:29:b5:16:db'
set interfaces wireguard wg01 address '10.44.44.2/30'
set interfaces wireguard wg01 peer tun-wg02 allowed-ips '10.44.44.1/32'
set interfaces wireguard wg01 peer tun-wg02 allowed-ips '10.10.20.0/24'
set interfaces wireguard wg01 peer tun-wg02 endpoint '192.168.47.20:51820'
set interfaces wireguard wg02 address '10.88.88.2/30'
set interfaces wireguard wg02 peer tun-wg04 allowed-ips '10.10.20.0/24'
set interfaces wireguard wg02 peer tun-wg04 endpoint '10.30.30.20:51840'
set protocols bgp 65002 address-family ipv4-unicast network 192.168.40.0/24
set protocols bgp 65002 neighbor 10.44.44.1 remote-as '65001'
set protocols bgp 65002 neighbor 10.44.44.1 update-source '10.44.44.2'
set protocols bgp 65002 timers holdtime '6'
set protocols bgp 65002 timers keepalive '2'
set service ssh
set system host-name 'R2'
set system login user vyos authentication encrypted-password '$6$Echv46oLnp5O/o$0JCnLzgSZ1j2LGFX9DL3Nx97IrfKDqNJbyDv8am3pU0kmQUzyzNtO3ZV/.Fd0klziYZ5h.zX6wZRGhrnIw5VT1'
