Configuration system temporarily locked due to another commit in progress
Hi All
Im running 1.4-rolling-202201080317 as a kvm guest, which I rebooted in order to add an extra interface.
Post reboot, the boot sequence stops at
[ OK ] Reached target Login Prompts.
[ 26.708314] vyos-router[886]: Waiting for NICs to settle down: settled in 1sec…
[ 34.575662] vyos-router[999]: Started watchfrr.
[ 40.135526] vyos-router[886]: Mounting VyOS Config…done.
but I am able to ssh in after a few minutes.
I try to configure the new interface, only to see Configuration system temporarily locked due to another commit in progress when attempting to commit.
I found the processes, killed them, rebooted again, but this still occurs.
Please how do I fix this?
Can you share more information on how to reproduce this error? Router config, hypervisor, and steps.
Did you try with another vyos version?
No, I havent tried other versions.
vyOS is running in on a centos stream 8 kvm hypervisor.
I graphically added a new network interface on the vm using virt-manager, because the vm had run out of hot-pluggable pci slots, causing virsh attach-interface --domain vyos0 --type bridge --source br1005 --model virtio --config --live to fail with a No more available PCI slots error.
Rebooting is necessary after the new virtio network interface was added in order for the vyOS vm to see it.
I noticed after rebooting the boot sequence didnt end with the login prompt as it normally should, but I noticed other kvm guests using the vyOS vm as their router were able to communicate online so I tried ssh-ing in which worked.
Resolution:
I noticed from grep-ing the commit process (ps aux | grep [c]ommit and sudo systemctl status <PID>) that it was the vyos-router.service seemingly stuck on scp-ing some old config files in /tmp:
├─3244 /bin/run-parts --regex=[1]+$ – /etc/commit/post-hooks.d
├─3260 /usr/bin/perl /etc/commit/post-hooks.d/02vyatta-commit-push.pl
└─3265 python3 -c from vyos.remote import upload; upload(“/tmp/config.boot.3260”, "scp://user:password@:/home//config.boot-gw00.inf>
I deleted the tmp files, and rebooted, but same situation repeated itself. I noticed there were 3 config.boot files in /tmp, I have no idea if this is normal.
What fixed it was to restart the vyos-router.service and the boot process completes to the login prompt as before.
  1. a-zA-Z0-9._- ↩︎
I do not have Centos for testing this.
I tried to reproduce this error, but had no success on other platforms, with different vyos versions. After adding new NIC, VM booted without troubles.
