Configuring roadwarrior to connect remotely to local LAN
hi there,
I am trying to configure a simple WireGuard RoadWarrior, so as to be able to connect to my local LAN when not at home and access local services running on another machine in the LAN.
I am unable to test whether the config works because I don’t know how to point to VyOS.
I am on VyOS 1.5-rolling-202310060022 on bare metal and have a very basic setup (below full config). The topology is pretty simple: internet → (eth0) VyOS > (eth1) unamnaged switch → LAN
I looked at the latest docs and run this:
set interfaces wireguard wg0 address 10.172.24.1/24
set interfaces wireguard wg0 address 2001:db8:470:22::1/64
set interfaces wireguard wg0 port 2224
  1. Then generated the PEER-PUBLIC-KEY with run generate pki wireguard key-pair and added the rest of the client info:
set interfaces wireguard wg0 peer iPhone public-key PEER-PUBLIC-KEY
set interfaces wireguard wg0 peer iPhone allowed-ips 10.172.24.20/32
set interfaces wireguard wg0 peer iPhone allowed-ips 2001:db8:470:22::20/128
set interfaces wireguard wg0 peer iPhone persistent-keepalive 15
run generate pki wireguard preshared-key install interface wg0 peer iPhone
  1. Finally, I opened the iPhone WireGuard app and provided:
  • private key: VYOS-PRIVATE-KEY
  • adresses: 10.172.24.20/32, 2001:db8:470:22::20/128
And added a peer with:
  • public key: PEER-PUBLIC-KEY
  • preshared-key: PEER-PRESHSARED-KEY
  • Allowed IPs: 0.0.0.0/0, ::0
My issue is the endpoint. I guess I need to put the VyOS ip, but as I am behind CGN, the only way is to connect directly via IPv6. I do this for a number of services via CloudFlare on another machine in my network, but as far as I understand that wouldn’t work if I want to obfuscate my ip. Also whilst I do get an IPv6 from a LAN machine, I do not seem to be able to get an address with curl -6 ifconfig.io from VyOS itself (I do get the IPv4 address though).
Is there anything else I am missing? Am I right thinking I need to find a way to connect directly to VyOS? Should I add some config to get eth0 to also get an ipv6?
Many thanks and apologies if this is a dumb question. Also I know I need to setup the firewall, but haven’t quite cracked the guide yet - that’s another story.
This is the full config:
container {
    name adguardhome {
        allow-host-networks
        cap-add net-bind-service
        image docker.io/adguard/adguardhome:latest
        restart always
        volume adguardhome-conf {
            destination /opt/adguardhome/conf
            source /config/adguardhome/conf
        volume adguardhome-hosts {
            destination /etc/hosts
            mode ro
            source /etc/hosts
        volume adguardhome-work {
            destination /opt/adguardhome/work
            source /config/adguardhome/work
        address dhcp
        address dhcpv6
        description WAN
        dhcpv6-options {
            pd 0 {
                interface eth1 {
                    sla-id 1
                length 56
        hw-id ...
        address 10.32.0.1/24
        description LAN
        hw-id ...
        ipv6 {
            address {
                autoconf
    wireguard wg0 {
        peer iPhone {
            preshared-key PEER-PRESHSARED-KEY
        port 2224
        private-key VYOS-PRIVATE-KEY
    loopback lo {
nat {
        rule 100 {
            outbound-interface eth0
                address 10.32.0.0/24
            translation {
                address masquerade
service {
    dhcp-server {
        shared-network-name LAN {
            subnet 10.32.0.0/24 {
                default-router 10.32.0.1
                name-server 10.32.0.1
                range 0 {
                    start 10.32.0.50
                    stop 10.32.0.125
    ntp {
    router-advert {
        interface eth1 {
            other-config-flag
            prefix ::/64 {
    ssh {
system {
Right, the bit I was going on with is that I was sharing private keys, whereas these never leave the devices.
So, the peer generates its own pair of private/public keys, and the public goes on the list of peers on VyOS.
On the other hand, the public key from VyOS (not the private) is added from the peer device (iPhone) settings:
[Interface]
PrivateKey = # Generate locally and then added to VyOS with `set interfaces wireguard wg0 peer iPhone public-key`
Address = ip of the peer e.g. 10.172.24.20/32
[Peer]
PublicKey = # VyOS public key, shown when running `run generate pki wireguard key-pair install interface wg0`
AllowedIPs = 0.0.0.0/0, ::/0 # to route all traffic to wireguard
Endpoint = VyOS-ip:51820
