Hello.
I want to connect to a L2TP/IPSec tunnel as a normal client just like when using on Windows/Mac etc.
How can i achieve that? I log in with a preshared key and username/password and works on Windows
Hello.
L2TP client is not implemented.
There is the feature request T1229
Aaah damn okay.
What kind of VPN Client’s are there right now then?
Openvpn, sstp, wireguard
IpSec Ikev2 remote access vpn IPSec IKEv2 Remote Access VPN — VyOS 1.5.x (circinus) documentation
open vpn, wireguard, tailscale, netmake. you can integrate tailscal netmake, netbrid into the vyos , someone has done it. L2TP over IPsec is not security enough.
