I recently upgraded my VyOS router to VyOS 1.5-rolling-202403120022 (from a build around mid December) and started experiencing problems with what appeared to be DNS. I had a look at the logs and I’m seeing a lot of
Mar 17 18:18:29 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= PHYSIN=eth3 SRC=192.168.1.20 DST=192.168.1.1 LEN=81 TOS=0x00 PREC=0x00 TTL=64 ID=38518 DF PROTO=UDP SPT=49621 DPT=53 LEN=61
Mar 17 18:18:31 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= PHYSIN=eth3 SRC=192.168.1.20 DST=192.168.1.1 LEN=81 TOS=0x00 PREC=0x00 TTL=64 ID=38520 DF PROTO=UDP SPT=49621 DPT=53 LEN=61
Mar 17 18:18:43 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= PHYSIN=eth1 SRC=192.168.1.100 DST=192.168.1.1 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=16148 DF PROTO=UDP SPT=48317 DPT=53 LEN=39
Mar 17 18:18:48 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= PHYSIN=eth1 SRC=192.168.1.100 DST=192.168.1.1 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=16150 DF PROTO=UDP SPT=48317 DPT=53 LEN=39
Mar 17 18:18:53 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= PHYSIN=eth1 SRC=192.168.1.100 DST=192.168.1.1 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=16151 DF PROTO=UDP SPT=48317 DPT=53 LEN=39
Mar 17 18:18:54 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= PHYSIN=eth3 SRC=192.168.1.20 DST=192.168.1.1 LEN=81 TOS=0x00 PREC=0x00 TTL=64 ID=38521 DF PROTO=UDP SPT=49621 DPT=53 LEN=61
and even some from the router itself:
Mar 17 19:42:15 kernel: nf_ct_RAS: dropping packet: cannot process RAS message IN= OUT= SRC=192.168.1.1 DST=192.168.1.100 LEN=126 TOS=0x00 PREC=0x00 TTL=64 ID=3622 PROTO=UDP SPT=53 DPT=51790 LEN=106 UID=112 GID=119
This issue affects regular web browsing, though it becomes very apparent when doing lots of lookups, e.g. downloading from registry.npmjs.org, crates.io etc.
The quick “solution” was to disable the h323 module:
delete system conntrack modules h323
Here’s my semi <SNIP>ped config:
firewall {
ipv4 {
name LAN-LOCAL {
default-action accept
name LAN-WAN {
name LOCAL-LAN {
name LOCAL-WAN {
name WAN-LAN {
default-action drop
rule 5 {
action accept
state established
state related
rule 10 {
action drop
log
state invalid
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
<SNIP>
name WAN-LOCAL {
default-action drop
rule 5 {
action accept
state established
state related
rule 10 {
action drop
log
state invalid
rule 20 {
action accept
icmp {
protocol icmp
<SNIP>
ipv6 {
name LAN-LOCAL-6 {
name LAN-WAN-6 {
name LOCAL-LAN-6 {
name LOCAL-WAN-6 {
name WAN-LAN-6 {
default-action drop
rule 5 {
action accept
state established
state related
rule 10 {
action drop
log
state invalid
rule 20 {
action accept
icmpv6 {
protocol ipv6-icmp
name WAN-LOCAL-6 {
default-action drop
rule 5 {
action accept
state established
state related
rule 10 {
action drop
log
state invalid
rule 20 {
action accept
icmpv6 {
protocol ipv6-icmp
rule 21 {
action accept
hop-limit {
eq 255
icmpv6 {
type-name nd-router-advert
protocol ipv6-icmp
rule 22 {
action accept
icmpv6 {
type-name nd-neighbor-advert
log
protocol ipv6-icmp
rule 30 {
action accept
description "dhcpv6 agent messages"
destination {
port 546
protocol udp
port 547
zone LAN {
default-action drop
from LOCAL {
firewall {
ipv6-name LOCAL-LAN-6
name LOCAL-LAN
from WAN {
firewall {
ipv6-name WAN-LAN-6
name WAN-LAN
interface br0
zone LOCAL {
default-action drop
from LAN {
firewall {
ipv6-name LAN-LOCAL-6
name LAN-LOCAL
from WAN {
firewall {
ipv6-name WAN-LOCAL-6
name WAN-LOCAL
local-zone
zone WAN {
default-action drop
from LAN {
firewall {
ipv6-name LAN-WAN-6
name LAN-WAN
from LOCAL {
firewall {
ipv6-name LOCAL-WAN-6
name LOCAL-WAN
interface eth0.10
bridge br0 {
address 192.168.1.1/24
description LAN
member {
interface eth1 {
interface eth2 {
interface eth3 {
interface eth4 {
interface eth5 {
hw-id 3c:ec:ef:46:91:d0
vif 10 {
address dhcp
address dhcpv6
description "<SNIP> VLAN"
dhcpv6-options {
pd 0 {
interface br0 {
address 1
sla-id 0
length 56
mtu 1500
hw-id 3c:ec:ef:46:91:d1
ethernet eth2 {
hw-id 3c:ec:ef:46:91:d2
ethernet eth3 {
hw-id 3c:ec:ef:46:91:d3
ethernet eth4 {
hw-id 3c:ec:ef:46:91:d4
ethernet eth5 {
hw-id 3c:ec:ef:46:91:d5
ethernet eth6 {
hw-id 3c:ec:ef:46:97:c2
ethernet eth7 {
hw-id 3c:ec:ef:46:97:c3
loopback lo {
nat {
destination {
<SNIP>
rule 10 {
outbound-interface {
name eth0.10
address 192.168.0.0/16
translation {
address masquerade
<SNIP>
service {
dhcp-server {
hostfile-update
shared-network-name LAN {
subnet 192.168.1.0/24 {
lease 86400
option {
default-router 192.168.1.1
domain-name localdomain
name-server 192.168.1.1
range 0 {
start 192.168.1.100
stop 192.168.1.254
<SNIP>
subnet-id 1
dns {
forwarding {
allow-from 192.168.1.0/24
cache-size 1000000
dnssec validate
listen-address 192.168.1.1
ntp {
allow-client {
address 0.0.0.0/0
address ::/0
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
router-advert {
interface br0 {
link-mtu 1500
prefix ::/64 {
snmp {
listen-address 192.168.1.1 {
location <SNIP>
v3 {
<SNIP>
ssh {
port 22
system {
config-management {
commit-revisions 100
conntrack {
modules {
ftp
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
host-name vyos
login {
user vyos {
authentication {
encrypted-password <SNIP>
plaintext-password ""
syslog {
global {
facility all {
level info
facility local7 {
level debug
time-zone Pacific/Auckland
