Conntrack not disabled when all modules are disabled
I have done the same process for a lot of customers (same setup) but we usually just disable sip. This time I deleted all the conntrack modules; figured I didn’t need them.
Software SIP ALG is detected: Screen Shot 2022-10-20 at 10.23.17 AM
Version:
Release train: equuleus
Build commit ID: 7ce86511888635
Architecture: x86_64
It’s a custom build (docker image, no customizations, so our version number shows as 2022.09)
Config (relevant section):
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 115200
host-name vyos
login {
user vyos {
authentication {
ntp {
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
syslog {
global {
facility all {
level info
facility protocols {
level debug
Reboot proof:
vyos@vyos:~$ show system uptime
14:30:20 up 11 min, 1 user, load average: 0.00, 0.00, 0.00
Example of conntrack table still after reboot:
show conntrack table ipv4
TCP state codes: SS - SYN SENT, SR - SYN RECEIVED, ES - ESTABLISHED,
FW - FIN WAIT, CW - CLOSE WAIT, LA - LAST ACK,
TW - TIME WAIT, CL - CLOSE, LI - LISTEN
CONN ID Source Destination Protocol TIMEOUT
4110764646 10.0.0.99:64761 1.1.1.1:8080 tcp [6] ES 431995
When adding back 1 conntrack:
Config:
system {
config-management {
conntrack {
modules {
tftp
console {
device ttyS0 {
speed 115200
rebooted and now I receive: Screen Shot 2022-10-20 at 10.46.28 AM
What is the VyOS version used here?
@zsdc
Sorry about that; I thought I included it.
Thanks a lot for the information! I think that this is the problem: ⚓ T4769 Conntrack settings are not apply properly
Easy fix, until it is not fixed in the upstream, will be an empty conntrack config:
delete system conntrack
With an empty config, a proper configuration script will be executed and conntrack/NAT helpers configured just like you expect.
