Cont. Clear all DHCP leases
This is in regards to discussion.
tjh: I tried your recommendation, but get similar result.
show dhcp server leases | grep 'free' | awk 'NR >2 {print $1}' | xargs -I {} clear dhcp-server lease {}
Usage: clear [options]
Options:
  -T TERM     use this instead of $TERM
  -V          print curses-version
  -x          do not try to clear scrollback
Options:
Is there a way to run xargs -I {} under vyos?
I may have found a way just to get rid of the free leases :slight_smile:
Each time you run clear dhcp lease $IP it asks
This will restart DHCP server.
Continue? [y/N]
So came up with script below which grabs only the “free” leases and loops through removing each one, one at a time. Need to sleep long enough to restart the dhcp service. Tried using yes n | for no, but that did not continue with deletion.
show dhcp server lease | grep "free" | awk '{print $1}' | while read ip; do
  yes | clear dhcp lease $ip
  sleep 5  # Sleep for 5 seconds after clearing each lease
done
Seems to work …
