I created a container, paired it with a network…
… it looks like this:
$ show container
name dns {
network dns {
address xxx.xxx.0.53
network dns {
prefix xxx.xxx.0.0/24
I actually started writing this months ago, since then I learned veth interfaces are used for it, that they connect to a bridge of veth interface pairs in which the common gateway address is assigned, the
x.x.x.1or equivalent.
The container is indeed appearing to received the address assigned (…53), according to the container itself (ip a and the like) but from the network it wouldn’t respond on it own address.
I started ping tests from the container, observed the traffic from wherever I could (firewalls, switches, etc) and learned that it came from the address that it’s supposed to be the container’s gateway address (…1), and indeed it responded to that address yet that’s not what it believes, so to speak, nor what it’s supposed to have as its address.
Why? Did I misunderstand set container network dns prefix '10.53.0.53/32'1 sets the container’s address to 10.53.0.53? If that’s not what that’s for, how can I set fixed direct addresses on containers? macvlan/ipvlan/macvtap/ipvtap for instance. I tried that too on my own but failed spectacularly. I had the most perfect config and I had to shut it down. ![]()
Thanks for your help.
1
I also tried CIDRs less shorter than a /30 BTW, but normally at least for virtual IP addrs /32s work summarized in a /24 over OSPF.
