Content mismatch between 'stable' and 'equuleus' documentation
I’m not quite sure where to put this, so it might be at the wrong place and I’m not even sure if this is a bug or if I’m completely misunderstanding the way the documentation under docs.vyos.io is built, so please bare with me.
When looking at the documentation under Configuration Guide — VyOS 1.3.x (equuleus) documentation (note the ‘equuleus’ part in the URL) there is a chapter which explains the configuration of container images, although VyOS 1.3 does not have this functionality at the moment.
When looking at Configuration Guide — VyOS 1.3.x (equuleus) documentation (note the ‘stable’ part in the URL) there is no such chapter.
So, if I’m not mistaken, there are two issues right now:
  1. the documentation for 1.3 contains functionality this version does not have
  2. the documentation for ‘stable’ and ‘equuleus’ are not the same / do not have the same source
Containers will be available in the subsequent EPA/LTS releases
Understood, thank you for clearing that up.
