Hi guys.
Sorry for bothering and make this noob question.
I have a Cisco DM VPN config that I want to implement on VyOS.
Can anyone help to convert this cisco dmvpn into VyOS ?
Config :
crypto isakmp policy 300
encr 3des
authentication pre-share
group 2
crypto isakmp key 6 s@@@12cm address 192.169.4.166
crypto ipsec transform-set DM-SET esp-3des esp-sha-hmac
crypto ipsec profile DM
set security-association lifetime seconds 120
set transform-set DM-SET
interface Tunnel306
bandwidth 2048
ip address 10.50.4.121 255.255.255.0
ip nhrp map 10.50.4.1 192.169.4.166
ip nhrp map multicast 192.169.4.166
ip nhrp holdtime 300
ip nhrp nhs 10.50.4.1
ip nhrp registration timeout 300
delay 1000
tunnel source “your wan ip address”
tunnel destination 192.169.4.166
tunnel key 1979
tunnel protection ipsec profile DM
ip route 192.168.12.0 255.255.255.240 10.50.4.1 name DMVPN
ip route 192.168.25.0 255.255.255.0 10.50.4.1 name DMVPN
Thanks you for response.
I’ve set the configuration, after VPN connected I must able to ping IP address of : 10.50.4.1, but I got time out .
I’ve call the other site person (Cisco side) and they said the connection is not connected.
Here is the debug commands I used to find the problem, Can you check where is the problem? (is it any other command to debug that I need?)
-- The `10.139.1.2` IP Address is my WAN address.
-- The `192.169.4.166` is the Cisco Device IP address (Cisco VPN Server) :
-- The `10.50.4.1` I must able to ping after VPN connected <-- PROBLEM IS HERE
vyos@vyos:~$ ping 192.169.4.166
PING 192.169.4.166 (192.169.4.166) 56(84) bytes of data.
64 bytes from 192.169.4.166: icmp_seq=1 ttl=251 time=21.6 ms
64 bytes from 192.169.4.166: icmp_seq=2 ttl=251 time=21.4 ms
4 packets transmitted, 4 received, 0% packet loss, time 3006ms
vyos@vyos:~$
vyos@vyos:~$
vyos@vyos:~$
vyos@vyos:~$ sh vpn ipsec sa
Connection State Uptime Bytes In/Out Packets In/Out Remote address Remote ID Proposal
vyos@vyos:~$
vyos@vyos:~$ sh vpn ike sa
Peer ID / IP Local ID / IP
192.169.4.166 192.169.4.166 10.139.1.2 10.139.1.2
State IKEVer Encrypt Hash D-H Group NAT-T A-Time L-Time
up IKEv1 3DES_CBC HMAC_SHA1_96 MODP_1024 no 183 0
vyos@vyos:~$
vyos@vyos:~$
vyos@vyos:~$
vyos@vyos:~$ sudo ipsec statusall
Status of IKE charon daemon (strongSwan 5.9.1, Linux 5.10.131-amd64-vyos, x86_64):
uptime: 16 minutes, since Mar 20 21:20:38 2022
malloc: sbrk 3096576, mmap 0, used 1069936, free 2026640
worker threads: 11 of 16 idle, 5/0/0/0 working, job queue: 0/0/0/0, scheduled: 4
loaded plugins: charon test-vectors ldap pkcs11 tpm aesni aes rc2 sha2 sha1 md5 mgf1 rdrand random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pkcs8 pkcs12 pgp dnskey sshkey pem openssl gcrypt af-alg fips-prf gmp curve25519 agent chapoly xcbc cmac hmac ctr ccm gcm drbg curl attr kernel-netlink resolve socket-default connmark stroke vici updown eap-identity eap-aka eap-md5 eap-gtc eap-mschapv2 eap-radius eap-tls eap-ttls eap-tnc xauth-generic xauth-eap xauth-pam tnc-tnccs dhcp lookip error-notify certexpire led addrblock counters
Listening IP addresses:
192.168.180.2
10.139.1.2
Connections:
dmvpn-NHRPVPN-tun0: %any...%any IKEv1
dmvpn-NHRPVPN-tun0: local: uses pre-shared key authentication
dmvpn-NHRPVPN-tun0: remote: uses pre-shared key authentication
dmvpn: child: dynamic[gre] === dynamic[gre] TRANSPORT
dmvpn-NHRPVPN-tun0[2]: ESTABLISHED 3 minutes ago, 10.139.1.2[10.139.1.2]...192.169.4.166[192.169.4.166]
dmvpn-NHRPVPN-tun0[2]: IKEv1 SPIs: 9788b98e7caa0636_i* 04b9118b21cec767_r, rekeying in 55 minutes
dmvpn-NHRPVPN-tun0[2]: IKE proposal: 3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
vyos@vyos:~$
vyos@vyos:~$
-- The device IP address that I must able to ping after tunnel/VPN is connected :
vyos@vyos:~$ ping 10.50.4.1
PING 10.50.4.1 (10.50.4.1) 56(84) bytes of data.
From 10.50.4.121 icmp_seq=7 Destination Host Unreachable
From 10.50.4.121 icmp_seq=8 Destination Host Unreachable
^C
--- 10.50.4.1 ping statistics ---
9 packets transmitted, 0 received, +2 errors, 100% packet loss, time 8231ms
pipe 2
vyos@vyos:~$ traceroute 10.50.4.1
traceroute to 10.50.4.1 (10.50.4.1), 30 hops max, 60 byte packets
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * * ^C
vyos@vyos:~$
Hello @root99
For the correct setting, you need to check the IPSec settings used on VyOS and the main Cisco (hub). Maybe the IPSec settings don’t match.
Thank you for your help, the connecting problem solve after changing the esp-group mode into tunnel.
set vpn ipsec esp-group ESP-DMVPN mode 'tunnel'
now I can able ping 10.50.4.1but have a new problem.
What is the new problem ?
Tunnel will disconnect after 10 minutes (~600 souncds).
-- Here is the debugs after tunnel disconnect (10.50.4.1 not pingable)
-- Empty IPSEC list !!?
-- Empty IKE list !!?
vyos@vyos:~$
What I tried?
I’ve enabled dead-peer-detection also but the problem not resolve , dead peer config :
set vpn ipsec ike-group IKE-DMVPN dead-peer-detection action 'restart'
set vpn ipsec ike-group IKE-DMVPN dead-peer-detection interval 20
set vpn ipsec ike-group IKE-DMVPN dead-peer-detection timeout 60
How it will reconnect?
If I call reset nhrp purge , tunnel will be connect exactly for 60 seconds.
. Is any suspicious found?
Another Thing is that my IPsec connection list is as below , is it normal?
(I have a session that ping trough tunnel constantly)
dmvpn down 1m37s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 21s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 22s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 23s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 24s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 26s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 27s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 28s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn down 29s 112B/112B 1B/1B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
dmvpn up 20s 2K/2K 20B/20B 192.169.4.166 192.169.4.166 3DES_CBC/HMAC_SHA1_96/MODP_1024
vyos@vyos:~$
