vyatta-cfg : Depends: libvyatta-cfg1 (>= 0.102.0+vyos2+current4) but it is not going to be installed
vyos-1x : Depends: hvinfo but it is not going to be installed
/tmp/vyos_install_stage_02.sh: line 47: /usr/share/vyos/version.json: No such file or directory
awk: line 2: function strftime never defined
awk: line 2: function systime never defined
Steps to recreate
Downloaded vyos-build
git clone -b current --single-branch GitHub - vyos/vyos-build: VyOS image build scripts
cd vyos-build/vyos-docker
docker build --no-cache --pull --compress -f Dockerfile -t vyos:1.4-date -u +%Y%m%d%H%M%S --build-arg BUILD_DATE=“date -u --rfc-3339=seconds” --build-arg VYOS_VERSION=1.4 --build-arg DEBIAN_VERSION=buster --progress plain …
I do not know what Iam doing wrong since ISO is created ok
Thanks
