Commit crash when I’m trying to import VRF to the other
Report time: 2022-12-13 19:16:20
Image version: VyOS 1.4-rolling-202212130326
Release train: current
Built by: autobuild@vyos.net
Built on: Tue 13 Dec 2022 03:26 UTC
Build UUID: f64b6613-642b-48f1-8e7c-1cbb7c8f8f87
Build commit ID: f56f9f9d7bc169
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: 7e548995-8213-4c7d-a0e9-14f8b970600f
File "/usr/libexec/vyos/conf_mode/protocols_bgp.py", line 388, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/protocols_bgp.py", line 379, in apply
frr_cfg.commit_configuration(bgp_daemon)
File "/usr/lib/python3/dist-packages/vyos/frr.py", line 480, in commit_configuration
raise ConfigurationNotValid(f'Config commit retry counter ({count_max}) exceeded for {daemon} dameon!')
vyos.frr.ConfigurationNotValid: Config commit retry counter (5) exceeded for bgpd dameon!
A crash occurs when this commands are used:
set interfaces ethernet eth1 address '10.0.255.69/27'
set interfaces ethernet eth1 vrf 'ROUTER'
set interfaces ethernet eth4 address '10.0.40.3/28'
set interfaces ethernet eth4 vrf 'CUSTOMER'
set protocols bgp parameters router-id '10.0.255.33'
set protocols bgp system-as '65011'
set vrf name CUSTOMER protocols bgp address-family ipv4-unicast rd vpn export '65011:1050'
set vrf name CUSTOMER protocols bgp address-family ipv4-unicast redistribute connected
set vrf name CUSTOMER protocols bgp address-family ipv4-unicast route-target vpn both '65011:1050'
set vrf name CUSTOMER protocols bgp system-as '65011'
set vrf name CUSTOMER table '300'
set vrf name ROUTER protocols bgp address-family ipv4-unicast rd vpn export '65011:1011'
set vrf name ROUTER protocols bgp address-family ipv4-unicast redistribute connected
set vrf name ROUTER protocols bgp address-family ipv4-unicast import vrf CUSTOMER
set vrf name ROUTER protocols bgp address-family ipv4-unicast route-target vpn both '65011:1011'
set vrf name ROUTER protocols bgp address-family ipv4-unicast route-target vpn import '65011:1050'
set vrf name ROUTER protocols bgp system-as '65011'
set vrf name ROUTER table '301'
