Default route not working after reboot
I have a default route setup using the following:
set protocol static route 0.0.0.0/0 next-hop 10.0.0.1
When it is initially setup and I run ip route I see:
default nhid 4 via 10.0.0.1 dev eth0 proto static metric 20
10.0.0.0/24 dev eth0 proto kernel scope link src 10.0.0.253
When I reboot and run ip route I see:
so the default route is missing.
Here is my config.boot:
        address 10.0.0.253/24
        description lan
        hw-id xx:xx:xx:xx:xx:xx
    loopback lo {
protocols {
    static {
        route 0.0.0.0/0 {
            next-hop 10.0.0.1 {
What does “show ip route” show after reboot?
Which version?
show version
Version info:
Version:          VyOS 1.3dev0-3942-ge890a70d1
Release train:    equuleus
Built by:         Sentrium S.L.
Built on:         2023-04-04 13:53:55 UTC
Build UUID:       ff390e75-5a03-4ab2-8498-1355e399b2cd
Build commit ID:  unknown
Architecture:     x86_64
System type:      bare metal
Hardware vendor:  HP
Hardware model:   HP ProDesk 600 G3 DM
Hardware S/N:     8CG8343BZR
Hardware UUID:    eb9311ab-2144-c4e4-6861-66903f739ace
show ip route shows zebra is not running
Also, if, after reboot, I recreate the route with:
delete protocol static route 0.0.0.0/0
commit
set protocols static route 0.0.0.0/0 next-hop 10.0.0.1
commit
save
exit
The route works again.
Not reproducible
VyOS 1.3.2-20230412083020
VyOS 1.3-stable-202304260442
Is it some specific image with custom packages?
I see correct routes after reboot
vyos@r1:~$ show ip route
       F - PBR, f - OpenFabric,
S>* 0.0.0.0/0 [1/0] via 192.168.122.1, eth0, weight 1, 00:02:18
C>* 192.0.2.25/32 is directly connected, dum0, 00:02:19
C>* 192.168.122.0/24 is directly connected, eth0, 00:02:19
vyos@r1:~$
Try another image, or provide a complete configuration “show conf com”
Also, could you provide logs after reboot? sudo journalctl -b | tee
show conf com
set interfaces ethernet eth0 address '10.0.0.253/24'
set interfaces ethernet eth0 description 'wan'
set interfaces ethernet eth0 hw-id '00:15:5d:01:b6:1d'
set interfaces loopback lo
set nat source rule 10 destination address '10.1.0.0/24'
set nat source rule 10 exclude
set nat source rule 10 outbound-interface 'eth0'
set nat source rule 10 source address '10.0.0.0/24'
set service ssh port '22'
set system domain-name '<REDACTED>'
set system host-name 'vyos2'
set system login user vyos authentication encrypted-password '<REDACTED>'
set system name-server '10.0.0.1'
set system ntp server time1.vyos.net
set system ntp server time2.vyos.net
set system ntp server time3.vyos.net
set system time-zone 'America/New_York'
set vpn ipsec esp-group ESP-AZURE compression 'disable'
set vpn ipsec esp-group ESP-AZURE lifetime '3600'
set vpn ipsec esp-group ESP-AZURE mode 'tunnel'
set vpn ipsec esp-group ESP-AZURE pfs 'dh-group2'
set vpn ipsec esp-group ESP-AZURE proposal 1 encryption 'aes256'
set vpn ipsec esp-group ESP-AZURE proposal 1 hash 'sha1'
set vpn ipsec ike-group IKE-AZURE close-action 'none'
set vpn ipsec ike-group IKE-AZURE dead-peer-detection action 'restart'
set vpn ipsec ike-group IKE-AZURE dead-peer-detection interval '15'
set vpn ipsec ike-group IKE-AZURE dead-peer-detection timeout '30'
set vpn ipsec ike-group IKE-AZURE ikev2-reauth 'yes'
set vpn ipsec ike-group IKE-AZURE key-exchange 'ikev2'
set vpn ipsec ike-group IKE-AZURE lifetime '28800'
set vpn ipsec ike-group IKE-AZURE proposal 1 dh-group '2'
set vpn ipsec ike-group IKE-AZURE proposal 1 encryption 'aes256'
set vpn ipsec ike-group IKE-AZURE proposal 1 hash 'sha1'
set vpn ipsec site-to-site peer 40.85.167.160 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 40.85.167.160 authentication pre-shared-secret '<REDACTED>'
set vpn ipsec site-to-site peer 40.85.167.160 connection-type 'respond'
set vpn ipsec site-to-site peer 40.85.167.160 default-esp-group 'ESP-AZURE'
set vpn ipsec site-to-site peer 40.85.167.160 ike-group 'IKE-AZURE'
set vpn ipsec site-to-site peer 40.85.167.160 ikev2-reauth 'inherit'
set vpn ipsec site-to-site peer 40.85.167.160 local-address '10.0.0.253'
set vpn ipsec site-to-site peer 40.85.167.160 tunnel 1 allow-nat-networks 'disable'
set vpn ipsec site-to-site peer 40.85.167.160 tunnel 1 allow-public-networks 'disable'
set vpn ipsec site-to-site peer 40.85.167.160 tunnel 1 local prefix '10.0.0.0/16'
set vpn ipsec site-to-site peer 40.85.167.160 tunnel 1 remote prefix '10.1.0.0/16'
Boot log attached
boot.log (170.7 KB)
At first look the issue could be with driver
Apr 27 08:56:36 vyos2 vyos-configd[40]: Received message: {"type": "node", "data": "VYOS_TAGNODE_VALUE=eth0/usr/libexec/vyos/conf_mode/interfaces-ethernet.py"}
Apr 27 08:56:36 vyos2 netplugd[197]: eth0: state INSANE flags 0x00011043 UP,BROADCAST,RUNNING,MULTICAST,10000 -> 0x00001002 BROADCAST,MULTICAST
Apr 27 08:56:36 vyos2 netplugd[671]: /etc/netplug/netplug eth0 probe -> pid 671
Apr 27 08:56:36 vyos2 netplugd[197]: eth0: state PROBING flags 0x00001002 BROADCAST,MULTICAST -> 0x00011043 UP,BROADCAST,RUNNING,MULTICAST,10000
Apr 27 08:56:36 vyos2 ZEBRA[235]: Received signal 11 at 1682600196 (si_addr 0xd0, PC 0x55becce1faf4); aborting...
Apr 27 08:56:36 vyos2 netplugd[197]: eth0: state PROBING_UP pid 671 exited status 0
Apr 27 08:56:36 vyos2 netplugd[673]: /etc/netplug/netplug eth0 in -> pid 673
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_backtrace_sigsafe+0x57) [0x7f026f7111a7]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_signal+0xdd) [0x7f026f71139d]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0x83124) [0x7f026f738124]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12730) [0x7f026f59d730]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(zebra_vxlan_macvlan_up+0x24) [0x55becce1faf4]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(if_up+0x1d8) [0x55beccdb6c18]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(netlink_link_change+0x90f) [0x55beccdb0b9f]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(netlink_parse_info+0x183) [0x55beccdb99f3]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(+0x38cc5) [0x55beccdb9cc5]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(thread_call+0x56) [0x7f026f7474b6]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(frr_run+0xe0) [0x7f026f70fda0]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(main+0x31d) [0x55beccdaad0d]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x7f026f3ef09b]
Apr 27 08:56:36 vyos2 ZEBRA[235]: /usr/lib/frr/zebra(_start+0x2a) [0x55beccdab65a]
Apr 27 08:56:36 vyos2 ZEBRA[235]: in thread kernel_read scheduled from zebra/kernel_netlink.c:406
Apr 27 08:56:36 vyos2 zebra[235]: unlink logbuf: Bad file descriptor (9)
Apr 27 08:56:36 vyos2 watchfrr[199]: [EC 268435457] zebra state -> down : read returned EOF
Apr 27 08:56:36 vyos2 watchfrr[199]: zebra state -> up : connect succeeded
Apr 27 08:56:36 vyos2 netplugd[197]: eth0: state INNING pid 673 exited status 256
Apr 27 08:56:36 vyos2 watchfrr[199]: [EC 268435457] zebra state -> down : unexpected read error: Connection reset by peer
Apr 27 08:56:36 vyos2 vyos-configd[40]: Sending response 1
Apr 27 08:57:36 vyos2 watchfrr[199]: Forked background command [pid 1147]: /usr/lib/frr/watchfrr.sh restart all
Zebra restarted and you get config without any routing, only connected networks.
I don’t not where you get this image but try another image
I did rebuild from the rolling version of 1.3 and it is now working. By the way, I was able to recreate the issue using the docker container for 1.3 so there must have been a change somewhere that fixed it.
Thank you very much @Viacheslav and @kyle I appreciate the help.
