Add a bridge:
admin@route-extern# set interfaces bridge br1 description "Test Bridge"
admin@route-extern# commit
Create a tunnel
set interfaces tunnel tun0 address '172.24.242.2/30'
set interfaces tunnel tun0 encapsulation 'gre-bridge'
set interfaces tunnel tun0 firewall local name 'WAN-LOCAL'
set interfaces tunnel tun0 local-ip '10.44.44.44'
set interfaces tunnel tun0 multicast 'disable'
set interfaces tunnel tun0 remote-ip '44.44.44.44'
set interfaces tunnel tun0 parameters ip bridge-group bridge br1
Delete the Bridge
admin@route-extern# delete interfaces bridge br1
Basically try and do anything with the tunnel. Deleting is a good way to trigger it.
admin@route-extern# delete interfaces tunnel tun0
[ interfaces tunnel tun0 parameters ip bridge-group bridge br1 ]
bridge br1 does not exist!
delete [ interfaces tunnel tun0 ] failed
Commit failed
Try to re-add the bridge
admin@route-extern# set interfaces bridge br1 description "Test"
And try to commit
device tun0 is not a slave of br1
But it doesn’t exist anymore
admin@route-extern# delete interfaces tunnel tun0 parameters ip bridge-group bridge br1
Nothing to delete (the specified value does not exist)
End result is you can’t commit. I had to hand edit the config.boot and reboot.
