The issue I’m having is that I can’t access hosts on my LAN from my laptop via wireguard
Any thoughts on how to fix this ?
I’ve tried different incantations of next-hop, but it doesn’t work
This is the error I’m getting
ping hermes
PING hermes (192.168.23.25): 56 data bytes
92 bytes from 192.168.10.1: Destination Host Unreachable
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 5400 8ab1 0 0000 3f 01 4e8b 192.168.10.3 192.168.23.25
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
And this is my config
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name FROM-EXTERNAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
name LAN-TO-LAN {
default-action accept
name TO-ROUTER {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
state {
new enable
rule 30 {
action accept
destination {
port 2294
protocol udp
rule 40 {
action accept
destination {
port 2284
protocol udp
send-redirects disable
source-validation disable
syn-cookies enable
address dhcp
description WAN
duplex auto
firewall {
in {
name FROM-EXTERNAL
local {
name TO-ROUTER
hw-id **************
smp-affinity auto
speed auto
address 192.168.23.1/24
description LAN
duplex auto
firewall {
in {
name LAN-TO-LAN
hw-id *************
smp-affinity auto
speed auto
traffic-policy {
out EGRESS_QOS
loopback lo {
openvpn vtun0 {
local-port 2294
mode server
openvpn-option comp-lzo
server {
domain-name *******************
name-server 192.168.23.1
push-route 192.168.23.0/24
subnet 192.168.70.0/24
tls {
wireguard wg0 {
address 192.168.10.1/24
description wg-roadwarrior
peer macbook {
allowed-ips 192.168.10.3/32
pubkey ****************
peer mobile {
allowed-ips 192.168.10.2/32
port 2284
nat {
destination {
rule 100 {
outbound-interface eth0
address 192.168.23.0/24
translation {
address masquerade
rule 200 {
address 192.168.10.0/24
translation {
address masquerade
protocols {
static {
interface-route 192.168.10.0/24 {
next-hop-interface wg0 {
service {
dhcp-server {
shared-network-name LAN_POOL {
authoritative
subnet 192.168.23.0/24 {
default-router 192.168.23.1
dns-server 192.168.23.1
lease 604800
range 0 {
start 192.168.23.200
stop 192.168.23.245
dns {
forwarding {
allow-from 0.0.0.0/0
allow-from ::/0
cache-size 2048
listen-on eth1
listen-on vtun0
listen-on wg0
system
ssh {
port 22
