Destination NAT translation port without address fails to commit
Tried to commit these commands on latest rolling:
set nat destination rule 10 destination port '443'
set nat destination rule 10 inbound-interface 'eth0'
set nat destination rule 10 protocol 'tcp'
set nat destination rule 10 translation port '3000'
Gives error “Destination NAT configuration error in rule 10: translation address not specified”
Came across this: ⚓ T2709 Destination NAT translation port without address fails to commit
Previous issue thats re-appeared?
Yes, needs to be fixed.
T2709 was for 1.3 version, and it was fixed.
This bug only present un 1.4
Do you want me to submit on phabricator?
This issue is even worse in NAT66 where VyOS submits wrong syntax to nft:
set nat66 destination rule 100 destination port 443
set nat66 destination rule 100 inbound-interface eth1
set nat66 destination rule 100 protocol tcp
set nat66 destination rule 100 translation port 3000
commit
That causes a crash in the UI:
  File "/usr/libexec/vyos/conf_mode/nat66.py", line 175, in <module>
    apply(c)
  File "/usr/libexec/vyos/conf_mode/nat66.py", line 157, in apply
    cmd(f'{nftables_nat66_config}')
  File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
    raise OSError(code, feedback)
PermissionError: [Errno 1] failed to run command: /tmp/vyos-nat66-rules.nft
returned:
exit code: 1
noteworthy:
cmd '/tmp/vyos-nat66-rules.nft'
returned (out):
returned (err):
/tmp/vyos-nat66-rules.nft:15:69-69: Error: syntax error, unexpected colon, expecting end of file or newline or semicolon
add rule ip6 nat PREROUTING iifname "eth1" counter tcp dport { 443 }:3000 comment "DST-NAT66-100"
[[nat66]] failed
Commit failed
I’m suspicious, this seems to be a use case where the erroneous command output is thrown due to lack of requisite validation logic, when a formal bug report is created please let me know and I’ll take the time to fix it.
Try to add the following configuration:
set nat66 destination rule 100 translation address <address>
and tell me the result.
Once I add an address to the commit, it goes through well and is properly submitted into netfilter:
table ip6 nat {
        chain PREROUTING {
                type nat hook prerouting priority dstnat; policy accept;
                iifname "eth1" counter packets 0 bytes 0 tcp dport 443 dnat to 2555:555:555:55::55:3000 comment "DST-NAT66-100"
Would you like me to open a bug report on phabricator?
You are welcome to open the official bug report if you like, it will assign a TASK ID to it and create an archive of the bug report so I might be able to fix it
https://phabricator.vyos.net/T4706
