Deterministic CGNAT
I want to do deterministic CGNAT with vyos. but I couldn’t find a document. can it be done?
Hi, You can start from here:
https://docs.vyos.io/en/latest/configuration/nat/cgnat.html
Hello
there is no information about deterministic in the document.
Hi, CGNAT as explained in the link it’s deterministic, every internal IP will use the same ip and same pool of ports (if u will not change port allocation and pool size)
