DHCP client issue - interface isn't picking address from DHCP
Hi guys,
I’ve got a small lab deployment with Hyper-V 2012 R2 where I use VyOS as a router to connect to external networks.
My setup:
  • eth0 is connecter to my vSwitch which is bridged to my wlan adapter in hyper-v
  • standard network adapter (it didn’t work with legacy one at all)
  • configured to receive its address via DHCP
With my home router and my phone working as a hot spot it works just fine receiving its address. But when I connect to my lab switch, which is HP 5500 EI switch, using wireless access point - it’s not working:
eth0 - u/u Internet
eth1 192.168.100.1/24 u/u Management
eth2 192.168.101.1/24 u/u Wireless
eth3 192.168.102.1/24 u/u Client
lo 127.0.0.1/8 u/u
I have a DHCP server running on my switch which is used for access points and other stuff. All devices are getting their IP addresses with no issues.
But:
  • connectivity works fine if I assign a static IP address to eth0;
  • if I connect a Win10 VM to the same vSwitch - it gets an IP address from 5500 EI, no issues;
  • if instead of my Internet vSwitch I connect it to my internal VM Network vSwitch where I’ve got another DHCP server running - no issues with getting IP address.
If I capture what’s happening on the interface:
vyos@vyos:~$ monitor interfaces ethernet eth0 traffic
Capturing traffic on eth0 …
0.000000 0.0.0.0 → 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x5560052d
2.572138 192.168.10.1 → 255.255.255.255 DHCP DHCP Offer - Transaction ID 0x5560052d
4.200164 0.0.0.0 → 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x5560052d
13.260000 0.0.0.0 → 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x5560052d
13.264215 192.168.10.1 → 255.255.255.255 DHCP DHCP Offer - Transaction ID 0x5560052d
23.728753 00:15:5d:64:0a:0f → 01:80:c2:00:00:0e LLDP Chassis Id = 00:15:5d:64:0a:0f Port Id = eth0 TTL = 120
27.460089 0.0.0.0 → 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x5560052d
27.464470 192.168.10.1 → 255.255.255.255 DHCP DHCP Offer - Transaction ID 0x5560052d
47.390230 0.0.0.0 → 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x5560052d
47.394774 192.168.10.1 → 255.255.255.255 DHCP DHCP Offer - Transaction ID 0x5560052d
53.778496 00:15:5d:64:0a:0f → 01:80:c2:00:00:0e LLDP Chassis Id = 00:15:5d:64:0a:0f Port Id = eth0 TTL = 120
No DHCP request, no DHCP Acknowledgement…
This is how it looks like when I connect eth0 to my VM Network vSwitch:
149.448706 0.0.0.0 → 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x3ad44515
149.449926 192.168.102.1 → 192.168.102.3 DHCP DHCP Offer - Transaction ID 0x3ad44515
149.450121 00:15:5d:64:0a:15 → ff:ff:ff:ff:ff:ff ARP Who has 192.168.102.3? Tell 192.168.102.1
149.450195 0.0.0.0 → 255.255.255.255 DHCP DHCP Request - Transaction ID 0x3ad44515
149.451258 192.168.102.1 → 192.168.102.3 DHCP DHCP ACK - Transaction ID 0x3ad44515
Any ideas what could be causing the issue?
At least, you’re halfway dora…
Does dhclient do any logging? You might be able to run dhclient in foreground, viewing all its messages
Moreover, do you have WAN_LOCAL rules in place, that might block incoming DHCP responses?
My current configuration is attached.
Where I can see the log you mentioned?
Compare DHCP offers.
use:
sudo tcpdump -i eth0 -n -vvv udp port 67 or 68
You can even use “-s 0 -w dhcp.pcap” to log to file which can be opened in wireshark.
As already can be seen , one is in IP unicast, the other a IP broadcast
See also:
Thanks for that.
UDP checksum issue…
tcpdump: WARNING: eth0: no IPv4 address assigned
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 byte s
08:36:22.533394 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP ( 17), length 328)
0.0.0.0.68 > 255.255.255.255.67: [udp sum ok] BOOTP/DHCP, Request from 00:15 :5d:64:0a:0f, length 300, xid 0xe912b63b, secs 46, Flags [none] (0x0000)
Client-Ethernet-Address 00:15:5d:64:0a:0f
Vendor-rfc1048 Extensions
Magic Cookie 0x63825363
DHCP-Message Option 53, length 1: Discover
Hostname Option 12, length 4: “vyos”
Parameter-Request Option 55, length 5:
Subnet-Mask, BR, Default-Gateway, Domain-Name-Server
MTU
END Option 255, length 0
PAD Option 0, length 0, occurs 43
08:36:22.591077 IP (tos 0xe0, ttl 255, id 53213, offset 0, flags [none], proto U DP (17), length 336)
192.168.10.1.67 > 255.255.255.255.68: [bad udp cksum ab76!] BOOTP/DHCP, Repl y, length 308, xid 0xe912b63b, Flags [Broadcast] (0x8000)
Your-IP 192.168.10.116
DHCP-Message Option 53, length 1: Offer
Server-ID Option 54, length 4: 192.168.10.1
Lease-Time Option 51, length 4: 7200
RN Option 58, length 4: 3600
RB Option 59, length 4: 6300
Subnet-Mask Option 1, length 4: 255.255.255.0
Default-Gateway Option 3, length 4: 192.168.10.1
Domain-Name-Server Option 6, length 4: 8.8.8.8
Domain-Name Option 15, length 10: “XXXXX”
PAD Option 0, length 0, occurs 10
It may be related to how it’s offloaded… I doesn’t look like it’s happening in VyOS:
vyos@vyos:~$ sudo ethtool -k eth0
Offload parameters for eth0:
rx-checksumming: off
tx-checksumming: off
scatter-gather: off
tcp-segmentation-offload: off
udp-fragmentation-offload: off
generic-segmentation-offload: off
generic-receive-offload: on
large-receive-offload: off
ntuple-filters: off
receive-hashing: off
To it may be somewhere in Hyper-V. Need to dig in this direction.
Disabled all offloading features in Hyper-V - no changes…
Windows machines being connected to the same vSwitch can easily get ip adresses from the DHCP…
We are having a very strange problem , that is we have a lan with 16 vlans and all the vlans have different DHCP for each vlan in the coreswitch (Cisco 6509) and all the clients in the 16 vlans are windows 7 clients , now the problem is that some machines are not getting IP Addresses , but if we see the registry settings in those machines we see that there is an ip address given by the dhcp server in the following key of registery
