DHCP-relay between different LANs
Hello all!
I am working on a project at school, which has given me a bit of speculation.
I am currently running Vyatta 6.6R1 on my routers, and I have a network setup shown in the attached pdf file.
You can see my config files on both routers aswell.
The problem persist of these problems:
No DHCP IP adresses given to the users in the 172.17.1.0/24 from my Windows 2008R2 dhcp server on the 172.16.1.0/24 network.
I have implemented a ipsec site to site vpn between the two networks, and the tunnel status is active.
Can anyone give me a hint of what might be wrong in my config?
Could it be some dhcp-relay options I haven’t set?
Thanks for reading!
/Thomas
See Services_6.5R1_v01.pdf, but you probably need to add
set service dhcp-relay interface eth1.171
set service dhcp-relay interface eth1.172
Thank you for the answer Carl!
This might be useful, although I believe I have already tried the suggestion you came up with.
I might have to try it again.
Again - thank you for your answer! :slight_smile:
/Thomas
