I’ve been experimenting with DHCP-relay, following this guide: DHCP Relay — VyOS 1.4.x (sagitta) documentation
show service dhcp-relay
interface eth1
server 10.0.1.4
relay-options {
relay-agents-packets discard
To get the example above to work, I also had to add interface eth2
to the configuration.
An article on EdgeOS states:
Add all interfaces that should participate in the DHCP Relay process, including the uplink port to the DHCP server.
Is this true also for VyOS? My configuration started working when I included the uplink interface at least. Should I update the documentation?
