Is the dhcp-relay function supported with a cluster? I’m experimenting with VYOS in a small lab environment, and have two VYOS virtual machines configured as a cluster, routing traffic between three subnets. The cluster works correctly for IP routing, but when I try to add dhcp-relay service to the cluster as in ‘set cluster group mycluster service dhcp-relay’ it says “not a valid service name” when I try to commit.
I tried setting up dhcp-relay directly on each cluster member as if there was no cluster, but this did not work.
Hoping I’m just missing something. There is not much documentation available on the WIKI regarding cluster configuration.
Thanks in advance…
