I’m testing an in-place DMVPN upgrade path where a VyOS 1.4.0 hub remains in service and a spoke is upgraded to VyOS 1.5 (2026.01.30-0025-rolling). After upgrading the spoke to 1.5, it doesn’t successfully register/connect to the 1.4 hub.
I have seen this post, and the OP’s situation seems similar to mine in that dynamic NBMA is involved. Before putting in a feature request, I was just hoping to get a maintainers perspective to confirm that my situation is indeed an interoperability issue between OpenNHRP and FRR nhrpd.
From what I’m reading, it looks like we’d just need an OpenNHRP-compatible discovery mode, right?
My configs are nearly identical to the VyOS documented examples.
Hub (1.4.0):
set interfaces tunnel tun223 address '10.249.0.1/23'
set interfaces tunnel tun223 enable-multicast
set interfaces tunnel tun223 encapsulation 'gre'
set interfaces tunnel tun223 parameters ip key '1'
set interfaces tunnel tun223 source-address '10.248.0.1'
set protocols nhrp tunnel tun223 cisco-authentication 'secret'
set protocols nhrp tunnel tun223 holding-time '300'
set protocols nhrp tunnel tun223 multicast 'dynamic'
set protocols nhrp tunnel tun223 redirect
set vpn ipsec profile NHRPVPN authentication mode 'pre-shared-secret'
set vpn ipsec profile NHRPVPN authentication pre-shared-secret 'secret'
set vpn ipsec profile NHRPVPN bind tunnel 'tun223'
set vpn ipsec profile NHRPVPN esp-group 'ESP-DMVPN'
set vpn ipsec profile NHRPVPN ike-group 'IKE-DMVPN'
Spoke (1.4.0 - working):
set interfaces tunnel tun223 address '10.249.0.98/23'
set interfaces tunnel tun223 source-address '0.0.0.0'
set protocols nhrp tunnel tun223 map 10.249.0.1/23 nbma-address '10.248.0.1'
set protocols nhrp tunnel tun223 map 10.249.0.1/23 register
Spoke (1.5 rolling - not working):
set interfaces tunnel tun223 address '10.249.0.200/32'
set interfaces tunnel tun223 source-interface 'eth0'
set protocols nhrp tunnel tun223 authentication 'secret'
set protocols nhrp tunnel tun223 holdtime '300'
set protocols nhrp tunnel tun223 network-id '1'
set protocols nhrp tunnel tun223 nhs tunnel-ip 10.249.0.1 nbma '10.248.0.1'
set protocols nhrp tunnel tun223 registration-no-unique
Shared IPSec config between all of them:
set vpn ipsec esp-group ESP-DMVPN lifetime '7200'
set vpn ipsec esp-group ESP-DMVPN mode 'transport'
set vpn ipsec esp-group ESP-DMVPN pfs 'dh-group14'
set vpn ipsec esp-group ESP-DMVPN proposal 1 encryption 'aes256'
set vpn ipsec esp-group ESP-DMVPN proposal 1 hash 'sha256'
set vpn ipsec ike-group IKE-DMVPN dead-peer-detection action 'restart'
set vpn ipsec ike-group IKE-DMVPN dead-peer-detection interval '60'
set vpn ipsec ike-group IKE-DMVPN dead-peer-detection timeout '120'
set vpn ipsec ike-group IKE-DMVPN key-exchange 'ikev2'
set vpn ipsec ike-group IKE-DMVPN lifetime '86400'
set vpn ipsec ike-group IKE-DMVPN proposal 1 dh-group '14'
set vpn ipsec ike-group IKE-DMVPN proposal 1 encryption 'aes256'
set vpn ipsec ike-group IKE-DMVPN proposal 1 hash 'sha256'
set vpn ipsec interface 'eth0'
