DMVPN dont work after hub rebooting.
In operational mode on spoke sides i do
reset nhrp purge tunnel
reset nhrp flush tunnel
and it helps.
How can i schedule this?
and it helps.
Should work in lithium version.
Thanks, but it’s not working, show vpn ipsec sa
on spoke side shows “tunnel status up”.
did somebody solve this problem ?? i have the same issue
i suppose, problem with ipsec which encrypted gre tunnel via profile, when i disabled it, everything work fine, how avoid this problem anybody know ?
problem was solved via DPD timers for ikev1
Thanks for sharing that
why didn’t you add the code into VyOS, without the code DPD does not work ?
