Vamp
April 19, 2018, 12:05am
1
Hello there,
I found a (i think) misspelling error
i update from 1.2.0-rolling+201804130337 to 1.2.0-rolling+201804180337
the older version the dns forwarding interface show:
set service dns forwarding listen-on 'eth1'
On new version:
set service dns forwarding 'listen-on'
I try to delete this value and set it again, but not working it say that the variable is the ‘listen-on’
Of course in this version DNS service not working on clients so i rollback to the working image.
It is possible (i not check it) that able to rewrite the config “by hand”, but it is not a optimal way.
syncer
April 19, 2018, 10:03am
2
It’s bug, we in play migration to PowerDNS recursor so can take some time to polish
Thanks for report!
Will update you once new version available for test
Vamp
April 19, 2018, 8:56pm
3
Ok please write if we able to update Nightly.
It means that you will plan a DNS server? It is a really good idea!
Line2
April 20, 2018, 5:41am
4
I tested on V1.2.0-rolling+201804200337. After update the configuration node ‘service dns forwarding’ has disappeared from the config tree. I reconfigured this and the ‘listen on’-part is ok now.
Vamp
April 20, 2018, 7:12am
5
It means this is the solution working?
https://phabricator.vyos.net/T603
syncer
April 20, 2018, 8:18am
6
yes
about to write on it, please give a try
Vamp
April 20, 2018, 4:57pm
7
OK, the latest version is working well. Not need to add the DNS interface field again.
