DNS Resolv Issues
I am having issues with DNS resolving. I can resolve through the bridge just fine, and also on servers on the IPMI network (LAN). I am unable to resolve on the firewall itself.
Ping on Firewall Server:
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=111 time=8.62 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=111 time=8.81 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=111 time=8.79 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=111 time=8.78 ms
^C
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3006ms
rtt min/avg/max/mdev = 8.618/8.749/8.812/0.077 ms
Ping using google.com:
ping: Unknown host: google.com
Nslookup for google.com on Firewall:
root@edge:~# nslookup google.com
;; communications error to 8.8.8.8#53: timed out
;; communications error to 8.8.4.4#53: timed out
;; UDP setup with 2001:4860:4860::8888#53(2001:4860:4860::8888) for google.com failed: network unreachable.
Config:
    bridge br0 {
        description "WAN Bridge"
        member {
            interface eth0 {
            interface eth1 {
        hw-id 0c:c4:7a:ba:e4:c4
        hw-id 0c:c4:7a:ba:e4:c5
    ethernet eth2 {
        address XX.XX.XX.XX/27
        description WAN-Access
        hw-id 0c:c4:7a:ba:e4:c6
    ethernet eth3 {
        hw-id 0c:c4:7a:ba:e4:c7
    ethernet eth4 {
        hw-id 0c:c4:7a:ba:e4:c8
    ethernet eth5 {
        address 10.1.0.1/16
        description IPMI
        hw-id 0c:c4:7a:ba:e4:c9
    loopback lo {
protocols {
    static {
        route 0.0.0.0/0 {
            interface eth0 {
            interface eth2 {
            next-hop XX.XX.XX.XX {
service {
    dns {
        forwarding {
            allow-from 0.0.0.0/0
            dhcp eth5
            ignore-hosts-file
            listen-address 10.1.0.1
            name-server 8.8.4.4 {
            name-server 8.8.8.8 {
            system
    ids {
        ddos-protection {
            alert-script /etc/notify_about_attack.sh
            direction in
            listen-interface eth0
            mode sflow
            network XX.XX.XX.XX/27
            sflow {
                listen-address 127.0.0.1
                port 6343
            threshold {
                general {
                    fps 1000
                    mbps 50
                    pps 10000
    ntp {
        allow-client {
            address 0.0.0.0/0
            address ::/0
        server time1.vyos.net {
        server time2.vyos.net {
        server time3.vyos.net {
    ssh {
        port 22
system {
    config-management {
        commit-revisions 100
    conntrack {
        modules {
            ftp
            h323
            nfs
            pptp
            sip
            sqlnet
            tftp
    console {
        device ttyS0 {
            speed 115200
    domain-search {
        domain dartvps.net
    host-name XX.net
    login {
        user vyos {
            authentication {
    name-server 8.8.8.8
    name-server 8.8.4.4
    name-server 2001:4860:4860::8888
    name-server 2001:4860:4860::8844
    sflow {
        agent-address 127.0.0.1
        interface eth0
        interface eth1
        polling 30
        sampling-rate 1024
        server 127.0.0.1 {
            port 6343
    syslog {
        global {
            facility all {
                level info
            facility local7 {
                level debug
Any help is greatly appreciated! (I am going on 2 days of trying to find the case)
I feel stupid, it took me to post this to take time to read over everything. This has been resolved!
Anyone facing the same issues, make sure you do not have default routes with interfaces :slight_smile:
Welcome the Vyos forums and it’s great you got your problem solved yourself, nice work.
