Do not recognize Ethernet card type HPE 530FLR SFP+ BCM57810S
Hello to everyone,
My hardware do not recognize ethernet card HPE 530FLR SFP+ with vyos 1.5 release. The previous operating system, Ubuntu 20, works fine.
How do I install a driver for Vyos to recognize hardware?
Share lspci information
02:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
02:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
02:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
02:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.0 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Slave Instrumentation & System Support (rev 05)
01:00.2 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Management Processor Support and Messaging (rev 05)
01:00.4 USB controller: Hewlett-Packard Company Integrated Lights-Out Standard Virtual USB Controller (rev 02)
06:00.0 Memory controller: Hewlett Packard Enterprise Device 005f
download to package: compsig and rpm
https://support.hpe.com/connect/s/softwaredetails?language=en_US&collectionId=MTX-5f7dae044b3b4d97
Try booting on a debian 12 (bookworm) livecd and run both “lspci” and “lsmod” and do so with latest VyOS 1.5 aswell and please paste all 4 outputs in this thread.
“lspci -v” can be handy aswell.
X@CR-VYOS-1:/home/X# lspci -v
00:00.0 Host bridge: Intel Corporation Xeon E5/Core i7 DMI2 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMI2
Flags: fast devsel, NUMA node 0
Capabilities: [90] Express Root Port (Slot-), MSI 00
Capabilities: [e0] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?> Capabilities: [144] Vendor Specific Information: ID=0004 Rev=1 Len=03c <?>
Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?> Capabilities: [280] Vendor Specific Information: ID=0004 Rev=2 Len=018 <?>
00:01.0 PCI bridge: Intel Corporation Xeon E5/Core i7 IIO PCI Express Root Port 1a (rev 07) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 1a
Flags: bus master, fast devsel, latency 0, IRQ 25, NUMA node 0
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: f7f00000-f7ffffff [size=1M] [32-bit]
Prefetchable memory behind bridge: c0000000-dfffffff [size=512M] [32-bit]
Capabilities: [40] Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 1a
Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?> Capabilities: [110] Access Control Services Capabilities: [148] Advanced Error Reporting Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?>
Capabilities: [250] Secondary PCI Express
Kernel driver in use: pcieport
00:01.1 PCI bridge: Intel Corporation Xeon E5/Core i7 IIO PCI Express Root Port 1b (rev 07) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 1b
Flags: bus master, fast devsel, latency 0, IRQ 26, NUMA node 0
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
Memory behind bridge: [disabled] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Capabilities: [40] Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 1b
00:03.0 PCI bridge: Intel Corporation Xeon E5/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode (rev 07) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode
Flags: bus master, fast devsel, latency 0, IRQ 27, NUMA node 0
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
Capabilities: [40] Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode
00:03.1 PCI bridge: Intel Corporation Xeon E5/Core i7 IIO PCI Express Root Port 3b (rev 07) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3b
Flags: bus master, fast devsel, latency 0, IRQ 28, NUMA node 0
Bus: primary=00, secondary=15, subordinate=15, sec-latency=0
Capabilities: [40] Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3b
00:03.2 PCI bridge: Intel Corporation Xeon E5/Core i7 IIO PCI Express Root Port 3c (rev 07) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3c
Flags: bus master, fast devsel, latency 0, IRQ 24, NUMA node 0
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Capabilities: [40] Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3c
Capabilities: [60] MSI: Enable- Count=1/2 Maskable+ 64bit-
00:03.3 PCI bridge: Intel Corporation Xeon E5/Core i7 IIO PCI Express Root Port 3d (rev 07) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3d
Bus: primary=00, secondary=16, subordinate=16, sec-latency=0
Capabilities: [40] Subsystem: Hewlett-Packard Company Xeon E5/Core i7 IIO PCI Express Root Port 3d
00:04.0 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 0 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 0
Flags: bus master, fast devsel, latency 0, IRQ 35, NUMA node 0
Memory at f64f0000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [80] MSI-X: Enable+ Count=1 Masked-
Capabilities: [90] Express Root Complex Integrated Endpoint, MSI 00
Kernel driver in use: ioatdma
00:04.1 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 1 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 1
Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 0
Memory at f64e0000 (64-bit, non-prefetchable) [size=16K]
00:04.2 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 2 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 2
Memory at f64d0000 (64-bit, non-prefetchable) [size=16K]
00:04.3 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 3 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 3
Memory at f64c0000 (64-bit, non-prefetchable) [size=16K]
00:04.4 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 4 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 4
Memory at f64b0000 (64-bit, non-prefetchable) [size=16K]
00:04.5 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 5 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 5
Memory at f64a0000 (64-bit, non-prefetchable) [size=16K]
00:04.6 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 6 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 6
Memory at f6490000 (64-bit, non-prefetchable) [size=16K]
00:04.7 System peripheral: Intel Corporation Xeon E5/Core i7 DMA Channel 7 (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 DMA Channel 7
Memory at f6480000 (64-bit, non-prefetchable) [size=16K]
00:05.0 System peripheral: Intel Corporation Xeon E5/Core i7 Address Map, VTd_Misc, System Management (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 Address Map, VTd_Misc, System Management
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
00:05.2 System peripheral: Intel Corporation Xeon E5/Core i7 Control Status and Global Errors (rev 07)
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 Control Status and Global Errors
00:05.4 PIC: Intel Corporation Xeon E5/Core i7 I/O APIC (rev 07) (prog-if 20 [IO(X)-APIC])
Subsystem: Hewlett-Packard Company Xeon E5/Core i7 I/O APIC
Flags: bus master, fast devsel, latency 0, NUMA node 0
Memory at f6470000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [6c] Power Management version 3
00:11.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Virtual Root Port (rev 05) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Virtual Root Port
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Bus: primary=00, secondary=18, subordinate=18, sec-latency=0
Capabilities: [40] Express Root Port (Slot-), MSI 00
Capabilities: [80] Power Management version 3
Capabilities: [88] Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Virtual Root Port
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [100] Advanced Error Reporting
Capabilities: [138] Access Control Services
00:1a.0 USB controller: Intel Corporation C600/X79 series chipset USB2 Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Subsystem: Hewlett-Packard Company HP DL360e G8
Flags: bus master, medium devsel, latency 0, IRQ 21, NUMA node 0
Memory at f6460000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1c.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Root Port 1
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Root Port 1
Capabilities: [a0] Power Management version 2
00:1c.4 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 5 (rev b5) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Root Port 5
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 5000-5fff [size=4K] [16-bit]
Memory behind bridge: f7700000-f7efffff [size=8M] [32-bit]
Prefetchable memory behind bridge: bc000000-bc0fffff [size=1M] [32-bit]
Capabilities: [90] Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Root Port 5
00:1c.7 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 8 (rev b5) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Root Port 8
Flags: bus master, fast devsel, latency 0, IRQ 19, NUMA node 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 3000-3fff [size=4K] [16-bit]
Memory behind bridge: f6500000-f76fffff [size=18M] [32-bit]
Prefetchable memory behind bridge: bf000000-bfffffff [size=16M] [32-bit]
Capabilities: [90] Subsystem: Hewlett-Packard Company C600/X79 series chipset PCI Express Root Port 8
00:1d.0 USB controller: Intel Corporation C600/X79 series chipset USB2 Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Subsystem: Hewlett-Packard Company C600/X79 series chipset USB2 Enhanced Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 20, NUMA node 0
Memory at f6450000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
Subsystem: Hewlett-Packard Company 82801 PCI Bridge
Bus: primary=00, secondary=17, subordinate=17, sec-latency=32
Capabilities: [50] Subsystem: Hewlett-Packard Company 82801 PCI Bridge
00:1f.0 ISA bridge: Intel Corporation C600/X79 series chipset LPC Controller (rev 05)
Flags: bus master, medium devsel, latency 0, NUMA node 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 RAID bus controller: Intel Corporation C600/X79 series chipset SATA RAID Controller (rev 05)
Subsystem: Hewlett Packard Enterprise C600/X79 series chipset SATA RAID Controller
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 65, NUMA node 0
I/O ports at 4000 [size=8]
I/O ports at 4008 [size=4]
I/O ports at 4010 [size=8]
I/O ports at 4018 [size=4]
I/O ports at 4020 [size=32]
Memory at f6440000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ahci
Kernel modules: ahci
Subsystem: Hewlett-Packard Company iLO4
I/O ports at 3000 [size=256]
Memory at f76f0000 (32-bit, non-prefetchable) [size=512]
I/O ports at 3400 [size=256]
Capabilities: [78] Power Management version 3
Capabilities: [b0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [c0] Express Legacy Endpoint, MSI 00
Kernel driver in use: hpwdt
Kernel modules: hpwdt
01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 7, NUMA node 0
Memory at bf000000 (32-bit, prefetchable) [size=16M]
Memory at f76e0000 (32-bit, non-prefetchable) [size=16K]
Memory at f6800000 (32-bit, non-prefetchable) [size=8M]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [a8] Power Management version 3
I/O ports at 3800 [size=256]
Memory at f67f0000 (32-bit, non-prefetchable) [size=256]
Memory at f6600000 (32-bit, non-prefetchable) [size=1M]
Memory at f6580000 (32-bit, non-prefetchable) [size=512K]
Memory at f6570000 (32-bit, non-prefetchable) [size=32K]
Memory at f6560000 (32-bit, non-prefetchable) [size=32K]
Expansion ROM at f6500000 [virtual] [disabled] [size=64K]
Kernel driver in use: hpilo
Kernel modules: hpilo
01:00.4 USB controller: Hewlett-Packard Company Integrated Lights-Out Standard Virtual USB Controller (rev 02) (prog-if 00 [UHCI])
Flags: bus master, fast devsel, latency 0, IRQ 55, NUMA node 0
I/O ports at 3c00 [size=32]
Capabilities: [70] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [f0] Power Management version 3
Kernel driver in use: uhci_hcd
Kernel modules: uhci_hcd
DeviceName: NIC Port 1
Subsystem: Hewlett-Packard Company Ethernet 1Gb 4-port 366i Adapter
Memory at f7e00000 (32-bit, non-prefetchable) [size=1M]
I/O ports at 5000 [size=32]
Memory at f7df0000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at f7700000 [virtual] [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=10 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number d8-9d-67-ff-ff-63-2c-d8
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1c0] Latency Tolerance Reporting
Capabilities: [1d0] Access Control Services
Kernel driver in use: igb
Kernel modules: igb
DeviceName: NIC Port 2
Flags: bus master, fast devsel, latency 0, IRQ 17, NUMA node 0
Memory at f7c00000 (32-bit, non-prefetchable) [size=1M]
I/O ports at 5020 [size=32]
Memory at f7bf0000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at f7900000 [virtual] [disabled] [size=512K]
Kernel modules: igb
DeviceName: NIC Port 3
Flags: bus master, fast devsel, latency 0, IRQ 18, NUMA node 0
Memory at f7a00000 (32-bit, non-prefetchable) [size=1M]
I/O ports at 5040 [size=32]
Memory at f79f0000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at f7b00000 [virtual] [disabled] [size=512K]
Kernel modules: igb
DeviceName: NIC Port 4
Memory at f7800000 (32-bit, non-prefetchable) [size=1M]
I/O ports at 5060 [size=32]
Memory at f77f0000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at f7d00000 [virtual] [disabled] [size=512K]
Kernel modules: igb
DeviceName: Memory Controller
Subsystem: Hewlett Packard Enterprise Device 005f
Flags: bus master, fast devsel, latency 0, IRQ 5, NUMA node 0
Memory at c0000000 (64-bit, prefetchable) [size=512M]
Memory at f7ff0000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [60] Power Management version 3
Capabilities: [a0] MSI-X: Enable- Count=2 Masked-
Capabilities: [c0] Express Endpoint, MSI 01
Capabilities: [160] Power Budgeting <?>
And whats the output if you boot on a liveimage of lets say Debian12 or Ubuntu where you said that the NIC is working?
It looks like you currently use the igb driver but I dont recall if its in-tree or out-of-tree driver when it comes to Intel NICs. Normally the out-of-tree drivers are the prefered ones.
Hi @Apachez,
I still haven’t had a chance to try your opportunity; the server (vyos ) is in remote location. I will try this weekend. After that, I will share the results.
This topic was automatically closed after 14 days. New replies are no longer allowed.
