I’m looking at the docs for using dynamic dns (http://vyos.net/wiki/Dynamic_DNS#ddclient_behind_NAT), and they say to use the following command if your interface doesn’t have a public ip:
set service dns dynamic interface eth0 use-web url
Does this actually work? I’m using 1.1.7, and it doesn’t appear to be a valid command. Any ideas?
Thanks!
Justin
Unicron
2
what are you trying to do?
Has to be entered with url behind it like:
this is just an example though, that url is invalid.
Thanks for the reply.
My vyos router has a private IP, and I need to publish my public IP. As far as I can tell, that’s the only option.
I see the mistake I made. I thought that the string “url” was meant to be replaced by the actual url. I was doing this:
I’ll try that when I get home. I did try to tab through the options, and “use-web” didn’t come up. So we’ll see!
Nope, doesn’t work! Is there anything I’m missing here?
[code]vyos@vyos# set service dns dynamic interface eth1 use-web url api.ipify.org
Configuration path: service dns dynamic interface eth1 [use-web] is not valid
Set failed[/code]
