I am planing to change how my connection works and I need some help to figure out what parts of VyOS I need to setup and change.
What I had done:
I started with a single Cable ISP which only provided DHCP IP addresses but they rarely change. So I setup my VyOS as a VM on VMware ESXi 5.5 as follows:
eth0 -> Cable DHCP
eth1 -> Internal LAN
Then later when I needed a second IP so I could provide two HTTPS sites I added the following:
eth2 -> Cable DHCP
Basically I created a second NIC in VMware and have both go to the same virtual and physical switch which links them to the modem. This caused the modem to see two different MACs and so each NIC got a different IP address and they changed less then once a year.
Thing is, in order to make this configuration work I had to setup the load-balancing section of VyOS and used it to make connections sticky.
What I did now:
So now I’ve also bought a Business DSL service which provides me with 14 static IP addresses. So I’ve setup the below as well:
eth3 -> Connection to the Kasda DSL modem/router (in bridged mode)
eth4 -> Internal network to be used for DMZ
pppoe0 -> Gets the gateway IP for the DSL link and is used to point to my /28 IP range.
I currently have the following sections configured:
- SNAT - for masquerading for the DHCP addresses
- DNAT - for each port I want filtered from the Cable ISP to different servers
- Load-Balancing - Setup to balance eth0 and eth2 and allow eth1 through.
- Firewall - Rules to filter as needed for the outside connections.
- Traffic-Policy - Used for QoS of my connection ( needed for VoIP purposes)
What I want to switch:
- I’d like each IP from my 14 DSL IP addresses to have either a 1:1 NAT to a specific server in my LAN (eth1), or be given to the DMZ facing NIC on a server (eth4).
- I’d like any connection coming into one of the 14 static DSL IPs to come in through pppoe0 and go back out the same way.
- I’d like any traffic generated from the inside to be sent out eth0 so that any web surfing traffic goes in and out of my Cable DHCP IPs.
- Using the above I should be able to split my connection so that servers run on DSL and surfing runs on Cable.
Here is my current Firewall config:
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
group {
network-group DMZ {
network 104.234.237.144/28
network-group LAN {
network 10.10.10.0/24
network-group VPN {
network 10.9.10.0/24
network 10.0.1.0/24
network 10.0.2.0/24
network 10.0.3.0/24
network-group iSCSI {
network 10.10.5.0/24
ipv6-src-route disable
ip-src-route disable
log-martians enable
name DMZ-IN {
default-action drop
enable-default-log
rule 1000 {
action accept
state {
established enable
related enable
rule 1001 {
action drop
state {
invalid enable
rule 9000 {
action accept
group {
network-group DMZ
state {
new enable
name DMZ-LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 11 {
action drop
state {
invalid enable
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
state {
new enable
rule 30 {
action accept
destination {
port 67
protocol udp
state {
new enable
rule 40 {
action accept
destination {
port 53
protocol tcp_udp
state {
new enable
rule 50 {
action accept
destination {
port 123
protocol udp
state {
new enable
name DMZ-OUT {
default-action drop
enable-default-log
rule 1000 {
action accept
state {
established enable
related enable
rule 1001 {
action drop
state {
invalid enable
rule 1010 {
action accept
icmp {
protocol icmp
rule 2010 {
action accept
group {
network-group VPN
rule 2020 {
action accept
group {
network-group LAN
rule 3000 {
action accept
description "Web Server"
destination {
address 104.234.237.146
port 22,80,443
protocol tcp
state {
new enable
name Exchange {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
destination {
port 443
log enable
protocol tcp
rule 21 {
action accept
destination {
port 80
log enable
protocol tcp
rule 22 {
action accept
destination {
port 25
log enable
protocol tcp
rule 23 {
action accept
destination {
port 993
log enable
protocol tcp
rule 24 {
action accept
destination {
port 995
log enable
protocol tcp
rule 25 {
action accept
destination {
port 22
log enable
protocol tcp
name Inbound {
default-action drop
rule 9 {
action accept
log enable
protocol gre
rule 10 {
action accept
state {
established enable
related enable
rule 11 {
action accept
destination {
port 80
log enable
protocol tcp
rule 12 {
action accept
destination {
port 22
log enable
protocol tcp
rule 13 {
action accept
destination {
port 443
log enable
protocol tcp
rule 14 {
action accept
destination {
port 500
log enable
protocol udp
rule 15 {
action accept
destination {
port 3389
log enable
protocol tcp
rule 16 {
action accept
destination {
port 5721
log enable
protocol tcp
rule 17 {
action accept
destination {
port 3074
log enable
protocol tcp
rule 18 {
action accept
destination {
port 5070
log enable
protocol udp
rule 19 {
action accept
destination {
port 5060
log enable
protocol udp
rule 20 {
action accept
destination {
port 10000-20000
log enable
protocol udp
rule 21 {
action accept
log enable
protocol esp
rule 22 {
action accept
destination {
port 1701
ipsec {
match-ipsec
protocol udp
rule 23 {
action accept
destination {
port 161
log enable
protocol udp
rule 24 {
action accept
destination {
port 4500
protocol udp
rule 25 {
action accept
icmp {
type 8
log enable
protocol icmp
rule 26 {
action accept
icmp {
type 0
log enable
protocol icmp
rule 27 {
action accept
destination {
port 587
log enable
protocol tcp
rule 28 {
action accept
destination {
port 465
log enable
protocol tcp
rule 29 {
action accept
icmp {
type 3
log enable
protocol icmp
rule 31 {
action accept
icmp {
type 11
log enable
protocol icmp
rule 32 {
action accept
destination {
port 1194
log enable
protocol udp
rule 33 {
action accept
destination {
port 8080
log enable
protocol tcp
rule 34 {
action accept
destination {
port 6001
log enable
protocol tcp
rule 50 {
action accept
destination {
address 10.10.10.0/24
log enable
rule 51 {
action accept
destination {
address 10.10.5.0/24
log enable
name LAN-IN {
default-action drop
enable-default-log
rule 1000 {
action accept
state {
established enable
related enable
rule 1001 {
action drop
state {
invalid enable
rule 9000 {
action accept
group {
network-group LAN
state {
new enable
name LAN-OUT {
default-action drop
enable-default-log
rule 1000 {
action accept
state {
established enable
related enable
rule 1001 {
action drop
state {
invalid enable
rule 1010 {
action accept
icmp {
protocol icmp
rule 2000 {
action accept
group {
network-group VPN
state {
new enable
rule 2020 {
action accept
group {
network-group DMZ
name Outbound {
default-action drop
rule 10 {
action accept
log enable
state {
new enable
name Router {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
destination {
port 1723
protocol tcp
rule 21 {
action accept
destination {
port 500
log enable
protocol udp
rule 22 {
action accept
destination {
port 1701
ipsec {
match-ipsec
log enable
protocol udp
rule 23 {
action accept
destination {
port 4500
log enable
protocol udp
rule 24 {
action accept
log enable
protocol esp
rule 25 {
action accept
destination {
port 1194
log enable
protocol udp
send-redirects enable
source-validation disable
state-policy {
established {
action accept
related {
action accept
syn-cookies enable
Here’s my current Interface config:
address dhcp
description Outside
duplex auto
firewall {
in {
name Inbound
local {
name Router
hw-id 00:50:56:a1:20:08
smp_affinity auto
speed auto
traffic-policy {
out Outbound
address 10.10.10.2/24
description Inside
duplex auto
hw-id 00:50:56:a1:4e:7d
smp_affinity auto
speed auto
ethernet eth2 {
address dhcp
description Exchange
duplex auto
firewall {
in {
name Exchange
hw-id 00:50:56:a1:2c:57
smp_affinity auto
speed auto
traffic-policy {
out Outbound
ethernet eth3 {
description "DSL Modem"
duplex auto
hw-id 00:50:56:a0:64:dc
pppoe 0 {
default-route auto
mtu 1492
name-server auto
password <cleaned>
user-id <cleaned>
smp_affinity auto
speed auto
ethernet eth4 {
description DMZ
duplex auto
hw-id 00:50:56:a0:1b:fe
smp_affinity auto
speed auto
loopback lo {
openvpn vtun0 {
description "OpenVPN Server Tunnel"
encryption aes256
hash sha512
local-host 135.0.94.79
local-port 1194
mode server
protocol udp
server {
client site3 {
ip 10.9.10.4
push-route 10.0.1.0/24
push-route 10.0.2.0/24
subnet 10.0.3.0/24
client site2 {
ip 10.9.10.3
push-route 10.0.3.0/24
subnet 10.0.2.0/24
client remote1 {
ip 10.9.10.5
client site1 {
ip 10.9.10.2
subnet 10.0.1.0/24
domain-name hecint.com
name-server 10.10.10.12
name-server 10.10.10.13
push-route 10.10.10.0/24
push-route 198.251.51.0/24
push-route 74.125.69.188/32
push-route 173.194.46.98/32
push-route 216.58.216.78/32
push-route 115.29.160.153/32
subnet 10.9.10.0/24
tls {
ca-cert-file /config/auth/keys/ca.crt
cert-file /config/auth/keys/vyatta.crt
dh-file /config/auth/keys/dh1024.pem
key-file /config/auth/keys/vyatta.key
Here’s my Load Balancer config:
load-balancing {
wan {
interface-health eth0 {
failure-count 5
nexthop dhcp
success-count 1
test 10 {
resp-time 5
target 135.0.199.31
ttl-limit 1
type ping
test 20 {
resp-time 5
target 135.0.199.49
ttl-limit 1
type ping
interface-health eth2 {
failure-count 5
nexthop dhcp
success-count 1
test 10 {
resp-time 5
target 135.0.199.31
ttl-limit 1
type ping
test 20 {
resp-time 5
target 135.0.199.49
ttl-limit 1
type ping
rule 1 {
destination {
address 10.9.10.0/24
exclude
inbound-interface eth1
protocol all
rule 2 {
destination {
address 10.0.1.0/24
exclude
protocol all
rule 3 {
destination {
exclude
protocol all
rule 4 {
destination {
address 10.0.2.0/24
exclude
protocol all
rule 5 {
destination {
address 10.0.3.0/24
exclude
protocol all
rule 6 {
destination {
address 104.234.237.144/28
exclude
inbound-interface eth4
protocol all
rule 100 {
failover
interface eth0 {
weight 255
interface eth2 {
weight 1
protocol all
sticky-connections {
inbound
Here’s my DNAT config:
nat {
destination {
rule 20 {
destination {
port 80
inbound-interface eth0
protocol tcp
translation {
address 10.10.10.60
port 80
rule 21 {
destination {
port 22
protocol tcp
translation {
address 10.10.10.60
port 22
rule 22 {
destination {
port 443
protocol tcp
translation {
address 10.10.10.60
port 443
rule 23 {
destination {
port 80
inbound-interface eth2
protocol tcp
translation {
address 10.10.10.29
port 80
rule 24 {
destination {
port 3389
protocol tcp
translation {
address 10.10.10.64
port 3389
rule 25 {
destination {
port 5721
protocol tcp
translation {
address 10.10.10.67
port 5721
rule 26 {
destination {
port 3074
protocol tcp
translation {
address 10.10.10.14
port 3074
rule 27 {
destination {
port 5070
protocol udp
translation {
address 10.10.10.10
port 5070
rule 28 {
destination {
port 5060
protocol udp
translation {
address 10.10.10.10
port 5060
rule 29 {
destination {
port 10000-20000
protocol udp
translation {
address 10.10.10.10
port 10000-20000
rule 30 {
destination {
port 25
protocol tcp
translation {
address 10.10.10.29
port 25
rule 31 {
destination {
port 22
protocol tcp
translation {
address 10.10.10.64
port 3389
rule 32 {
destination {
port 443
protocol tcp
translation {
address 10.10.10.29
port 443
rule 41 {
destination {
port 993
protocol tcp
translation {
address 10.10.10.29
port 993
rule 42 {
destination {
port 995
protocol tcp
translation {
address 10.10.10.29
port 995
rule 43 {
destination {
port 587
protocol tcp
translation {
address 10.10.10.15
port 587
rule 44 {
destination {
port 465
protocol tcp
translation {
address 10.10.10.15
port 465
rule 46 {
destination {
port 8080
protocol tcp
translation {
address 10.10.10.67
port 8080
rule 47 {
destination {
port 6001
protocol tcp
translation {
address 10.10.10.15
port 6001
rule 100 {
destination {
inbound-interface pppoe0
protocol tcp
translation {
address 10.10.10.66
Here’s my SNAT config:
rule 100 {
outbound-interface eth0
translation {
address masquerade
rule 101 {
translation {
address masquerade
rule 200 {
outbound-interface eth2
translation {
address masquerade
rule 201 {
translation {
address masquerade
Here’s my Protocol’s config:
protocols {
static {
route 10.0.1.0/24 {
next-hop 10.9.10.2 {
route 10.0.2.0/24 {
next-hop 10.9.10.3 {
route 10.0.3.0/24 {
next-hop 10.9.10.4 {
route 10.10.5.0/24 {
next-hop 10.10.10.25 {
route 192.168.100.0/24 {
next-hop 135.0.94.79 {
Here’s my Traffic Policy config:
traffic-policy {
shaper Outbound {
bandwidth 10mbps
class 10 {
bandwidth 20%
burst 15k
ceiling 100%
description "VoIP-RTP Traffic"
match VOIP-RTP {
ip {
dscp 46
queue-type fair-queue
class 20 {
bandwidth 5%
burst 15k
ceiling 100%
description "VoIP-SIP Traffic"
match VOIP-SIP {
ip {
dscp 26
default {
bandwidth 75%
burst 15k
ceiling 100%
description "QoS Policy for Home, Outbound"
Anyone know what I would need to change?
