Dynamic DNS with WAN failover
Running VyOS 1.5-rolling-202401250024. I have 2 WAN interfaces, a static IP fibre (eth0) and a dynamic IP LTE (eth1) for failover.
I set up dynamic DNS (Cloudflare) using a web request so that various host addresses will follow whichever interface is being used at the time.
The issue I’m having is that it seems while failover is working correctly for all LAN traffic, VyOS seems to be preferring the failover connection for its own traffic. Running ‘curl api.ipify.org’ returns the IP of the failover connection when both interfaces are active, rather than the primary. At the same time, LAN traffic is being identified as from the primary interface.
I assume that there is an issue with my NAT table, but I don’t understand it enough to debug it. At the moment, the source nat table just contains the below. Thanks!
 rule 101 {
     outbound-interface {
         name eth0
         address 10.70.0.0/16
     translation {
         address masquerade
 rule 102 {
         name eth1
     translation {
         address masquerade
It’s probably a bug (at least it looks like)
We need to check the logic, and how it tied or not to wan-loadbalancing
@sarthurdev I think it’s need to be addressed in new implementation of wan-loadbalance
Can you post the load balancer/failover config?
@sarthurdev sure, thanks
***@vyos# show load-balancing
 wan {
     flush-connections
     interface-health eth0 {
         failure-count 2
         nexthop dhcp
         success-count 2
         test 10 {
             resp-time 2
             target 1.1.1.1
             ttl-limit 1
             type ping
         test 20 {
             resp-time 2
             target 8.8.4.4
             ttl-limit 1
             type ping
     interface-health eth1 {
         failure-count 5
         nexthop dhcp
         success-count 5
         test 10 {
             resp-time 2
             target 8.8.8.8
             ttl-limit 1
             type ping
         test 20 {
             resp-time 2
             target 1.0.0.1
             ttl-limit 1
             type ping
     rule 1 {
         description "Ignore local traffic"
         destination {
         exclude
         inbound-interface eth+
         protocol all
     rule 100 {
         failover
         inbound-interface eth2
         interface eth0 {
             weight 5
         interface eth1 {
             weight 1
         protocol all
     rule 120 {
         failover
         inbound-interface eth2.20
         interface eth0 {
             weight 5
         interface eth1 {
             weight 1
         protocol all
     rule 130 {
         failover
         inbound-interface eth2.30
         interface eth0 {
             weight 5
         interface eth1 {
             weight 1
         protocol all
     rule 140 {
         failover
         inbound-interface eth2.40
         interface eth0 {
             weight 5
         interface eth1 {
             weight 1
         protocol all
     sticky-connections {
         inbound
Seems like there’s no LB logic configured for local generated traffic, than main routing table will be used. Check if default route on LTE interface is “best” (preferred), try altering its distance.
Good point.
@SCCFIT try set load-balancing wan enable-local-traffic
Ah, I must have missed that in the documentation… I’ve set that and it seems like it is working now, thanks!
