DynamicDNS With Cloudflare seems to not work
There’s another post about this from about 3 years ago. They got it working, but I cannot. I see that the built in version is ddclient version 3.9.1. I pulled the current github repo, they’re up to something like 3.10+. It works locally with that build. The config options are different.
Is it possible to update the ddclient version built in to vyos? I’m running a vyos build I built about a month ago from git.
For context, when I run the built in ddclient in debug mode, it says this:
WARNING:  file /var/cache/ddclient/ddclient.cache, line 3: Invalid Value for keyword 'ip' = ''
DEBUG:    get_ipv6: using if, eth0 reports [[actualpublicip]]
WARNING:  skipping update of [[actualdomaintoupdate]] from <nothing> to [[actualpublicip]].
WARNING:   last updated <never> but last attempt on Fri Feb 17 10:35:38 2023 failed.
Could you send the current VyOS “dns dynamic” configuration and
cat /run/ddclient/ddclient.conf ?
And working configuration for 3.10+
In any way we are working on integration " bookworm", it uses ddclient (3.10.0-2)
Do you use option ipv6-enable if it is IPv6 address?
set service dns dynamic interface eth2 ipv6-enable
+1 solution with update script Dynamic dns didn't supr ipv6 ip address assign - #5 by echowings
