This is with VyOS 1.5-rolling-202501110007. I have a router with 2x 40 GbE L3 links, each to a different Arista switch. I’m talking OSPF and iBGP to the switches, and it looks like ECMP is being set up correctly, but I’m seeing >99% of my outbound traffic on the same link, even after changing the multipath hash policy.
For this test, I’m most concerned with the route from my router to 10.0.0.7, which I’m using to run an HTTP load test through the router. I’m seeing 2 ECMP routes to this host, one through each interface:
$ show ip route 10.0.0.7
Routing entry for 10.0.0.7/32
Known via "ospf", distance 110, metric 12, best
Last update 00:19:01 ago
* 10.0.6.69, via eth4, weight 1
* 10.0.7.69, via eth6, weight 1
The kernel sees the same thing:
$ ip route show 10.0.0.7
10.0.0.7 nhid 84 proto ospf metric 20
nexthop via 10.0.6.69 dev eth4 weight 1
nexthop via 10.0.7.69 dev eth6 weight 1
I’ve set the IPv4 and IPv6 multipath hash to 1, which should include the source and destination ports in the ECMP hash. This should cause individual flows to be balanced across links, not just hosts:
set system sysctl parameter net.ipv4.fib_multipath_hash_policy value '1'
set system sysctl parameter net.ipv6.fib_multipath_hash_policy value '1'
However, when I open up 256 TCP connections from a single test server (10.0.0.7, as above) through the router, the return traffic for all of them ends up on the same interface. According to atop, I’m seeing 39 Gbps outbound on eth6 and 181 Mbps on eth4.
I saw the same behavior with a nightly from July before I upgraded this morning. Does anyone have any suggestions on how to debug this? Since I’m using 256 different TCP connections, I’d expect that the fib_multipath_hash_policy would send ~half of them over each interface, not 100% over a single link. I’ve also tried setting net.ipv4.fib_multipath_hash_fields=0xfff and using fib_multipath_hash_policy=3 (to change the hash on practically every stable field in each packet) with no obvious change in behavior.
