Attempting to load up up the nightly release of Vyos and get this error message on boot.
error: no suitable video mode found.
Booting in blind mode
Obviously i cannot get it to boot currently, sales person I spoke with said it’s supported on the 7512
The AS7512-32x requests 115200, I can attempt to change it and see if that works, I believe I tested with and without eufi
On boot, VyOS is trying to change it to 9600 because there are defined in config by default.
with 9600 baud to the switch which normally requires 115200, i get garbage on the putty session
Did you try to change to 9600 after GRUB begins to boot?
gave a blank screen, tried it a couple times
