Encaplimit equuleus ipip6
Hello !
On the crux version the creation of an ipip6 tunnel allows an ipv6 parameter encaplimit to none but on equuleus encaplimit only take integer numbers.
My ISP returns errors (and refuses to respond) when a packet contains an encaplimit in the header. Do you know if it is possible to set a value to encaplimit so that it no longer appears in packets sent by vyOS? A possibility of not sending encaplimit?
Hi @xtremxyz,
this is clearly a bug that you can no longer set encaplimit none - or that the config was not migrated to integers only. The encaplimit default is 4, what happens if you specify encaplimit 0 and test again?
Issue tracked via ⚓ T3406 tunnel: interface no longer supports specifying encaplimit none - or migrator is missing
Thanks for the answer :slight_smile: If I set encaplimit to 0 the header still contains an encaplimit field… While encaplimit to none does not send the field (on crux).
Corrected in latest version thank you !
