Using iproute2, you can use “ip addr add XXXXX peer YYYY dev ZZZ” to specify the address of the remote endpoint, for example using an ULA :
peer ADDRESS
the address of the remote endpoint for pointopoint
interfaces. Again, the ADDRESS may be followed by a slash
and a decimal number, encoding the network prefix length.
If a peer address is specified, the local address cannot
have a prefix length. The network prefix is associated
with the peer rather than with the local address.
(from ip-address(8) - Linux manual page)
Is there a way to do the same thing using VyOS configuration options?
Thanks,
