Hi everyone!
I’m trying to build vyos using the dockerfile following the directions from vyos-build/README.md at current · vyos/vyos-build · GitHub. Everything runs fine, except the make iso command.
This is the error that I’m facing:
Checking build configuration
[2019-06-05 17:14:52] lb clean
P: Cleaning chroot
Starting VyOS ISO image build
Setting up additional APT entries
Configuring live-build
[2019-06-05 17:14:52] lb config noauto --architectures amd64 --bootappend-live boot=live components hostname=vyos username=live nopersistence noautologin nonetworking union=overlay --linux-flavours amd64-vyos --linux-packages linux-image-4.19.32 --bootloader syslinux,grub-efi --binary-images iso-hybrid --debian-installer false --distribution jessie --iso-application VyOS --iso-publisher aldemaro@aldemaro.com.br --iso-volume VyOS --debootstrap-options --variant=minbase --exclude=isc-dhcp-client,isc-dhcp-common,ifupdown --include=apt-transport-https --mirror-bootstrap http://deb.debian.org/debian --mirror-chroot http://deb.debian.org/debian --mirror-chroot-security http://deb.debian.org/debian-security --mirror-binary http://deb.debian.org/debian --mirror-binary-security http://deb.debian.org/debian-security --archive-areas main contrib non-free --firmware-chroot false --firmware-binary false --updates false --security true --apt-options --yes -oAcquire::Check-Valid-Until=false --apt-indices false
P: Updating config tree for a debian/jessie/amd64 system
P: Symlinking hooks...
File "scripts/make-version-file", line 49, in <module>
repo = git.Repo('.')
File "/usr/lib/python3/dist-packages/git/repo/base.py", line 156, in __init__
raise InvalidGitRepositoryError(epath)
git.exc.InvalidGitRepositoryError: /root/vyos-build-crux
Makefile:14: recipe for target 'prepare' failed
make: *** [prepare] Error 1
Am I doing something wrong or is it a bug?
I tried to build using a bare metal server using Centos 7, Debian 8 and using a VM and got the same error.
