Error building ISO 1.3
I am trying to create an ISO 1.3 today and I get the following error:
…The following signatures were invalid: EXPKEYSIG 1B0C6205FD380FBB PowerDNS…
A search clears it up:
FD380FBB-pub.asc certificate has expired on June 7th
I guess it’s time to update the vyos/vyos-build image in DockerHub?
Is this true?
Or there is a workaround?
same error here. no idea how to fix
You can relatively easily build the docker image yourself. To save myself some grief, I always build a fresh docker image, then the vyos-1x package, then the ISO all at the same time.
any clue how to make my own docker, boz I build iso from github action
https://docs.vyos.io/en/stable/contributing/build-vyos.html#build-from-source
update the key: curl -sS https://repo.powerdns.com/FD380FBB-pub.asc > vyos-build/data/live-build-config/archives/pdns.key.chroot
Thank you very much. It works.
The problem is not with the DockerHub image, but with the github vyos-build repository.
But it would be better if such patches were not required.
Update
Please waiting for merge
