Error on adding a wireguard interface to OSPFv3
i have OSPF (ipv4) up and running with some ipsec-vti (+ neighbor’s) and wireguard (passive) interfaces
this is working fine.
now i’m trying to add OSPFv3 (IPv6) to it.
this works with de VTI interfaces:
XXX@rt01# show protocols ospfv3 | strip-private
 area 10.10.0.0 {
     range xxxx:xxxx:c2c:2bd9::/64 {
         advertise
     range xxxx:xxxx:fd32::/48 {
         advertise
 interface lo {
     area 10.10.0.0
     passive
 interface vti101 {
     area 10.10.0.0
     network point-to-point
 interface vti201 {
     area 0.0.0.0
 interface vti202 {
     area 0.0.0.0
 interface vti203 {
     area 0.0.0.0
 log-adjacency-changes {
     detail
 parameters {
     router-id xxx.xxx.255.1
but when i’m trying to add the wireguard interfaces i’m getting the following error:
rt01# compare
[protocols ospfv3 interface]
+ wg231 {
+     area "10.10.0.0"
+     passive
XXX@rt01# commit
[ protocols ospfv3 ]
  https://support.vyos.io/
- Make sure you are running the latest version of VyOS available at:
  https://vyos.net/get/
- Consult the community forum to see how to handle this issue:
  https://forum.vyos.io
- Join us on Slack where our users exchange help and advice:
  https://vyos.slack.com
  business policy requires it)
Report time:      2024-01-28 21:41:14
Image version:    VyOS 1.5-rolling-202401090834
Release train:    current
Built on:         Tue 09 Jan 2024 10:30 UTC
Build UUID:       350f1f79-e581-4dd2-956c-36b7ef1c5e5c
Build commit ID:  92195009af863c
Architecture:     x86_64
System type:      KVM guest
Hardware vendor:  Hetzner
Hardware model:   vServer
Hardware S/N:     14585311
Hardware UUID:    156eed2a-0020-4471-ad82-eecfe5de4127
  File "/usr/libexec/vyos/conf_mode/protocols_ospfv3.py", line 184, in <module>
    apply(c)
  File "/usr/libexec/vyos/conf_mode/protocols_ospfv3.py", line 175, in apply
    frr_cfg.commit_configuration(ospf6_daemon)
  File "/usr/lib/python3/dist-packages/vyos/frr.py", line 482, in commit_configuration
    raise ConfigurationNotValid(f'Config commit retry counter ({count_max}) exceeded for {daemon} dameon!')
vyos.frr.ConfigurationNotValid: Config commit retry counter (5) exceeded for ospf6d dameon!
[[protocols ospfv3]] failed
Commit failed
What gone wrong here?
Hi @Spookje - welcome to the Vyos forums.
You haven’t mentioned which version of Vyos you’re using, but regardless it sounds like you’ve hit a fairly concrete bug.
If you’re able, it would be great if you could write up the details on the https://vyos.dev page. But if you really don’t feel like doing that (you’ll need to create an account there if you don’t have one), please post as much detail here as you’re able, especially what version(s) you’ve tried and if any of them worked, and I or someone else can write up a ticket on your behalf.
Thanks for reporting it though!
Tim
Hi Tim,
The version was in the VyOS error report, that is why I skipped it:
I do have an https://vyos.dev/ account, so I will make an issue there.
https://vyos.dev/T6005
Fixed in latest 1.5 rolling release and upcoming 1.4.0-epa1 release.
