Hi guys,
I want to activate flow-accounting but i can’t cuz i received this:
Failed to start/stop flow-accounting
failed to run command: systemctl restart uacctd.service
returned:
exit code: 1
I try to restart it manualy and it’s the same issue.
Into the journalctl the message is next one:
Feb 05 10:50:48 router.100 systemd[1]: Starting ulog accounting daemon…
– Subject: A start job for unit uacctd.service has begun execution
– Defined-By: systemd
– Support: https://www.debian.org/support
– A start job for unit uacctd.service has begun execution.
– The job identifier is 11379.
Feb 05 10:50:48 router.100 uacctd[23086]: ERROR: [/etc/pmacct/uacctd.conf:12] Syntax error: missing ‘:’
Feb 05 10:50:48 router.100 systemd[1]: uacctd.service: Control process exited, code=exited, status=1/FA
– Subject: Unit process exited
– An ExecStart= process belonging to unit uacctd.service has exited.
– The process’ exit code is ‘exited’ and its exit status is 1.
Someoane can help me?
i want to use fastnetmon to monitor my trafic
Version: VyOS 1.3-rolling-202012160217
Release Train: equuleus
Built by: autobuild@vyos.net
Built on: Wed 16 Dec 2020 02:17 UTC
Thanks,
Alin.
