I tried to build a 1.4 release this morning ( clean build on debian12 ) and got the following error, is this a bug in the build scripts?
[2023-09-26 09:16:32] lb chroot_install-packages install
P: Begin installing packages (install pass)...
Reading package lists... Done
debconf is already the newest version (1.5.82).
gpgv is already the newest version (2.2.40-1.1).
gnupg is already the newest version (2.2.40-1.1).
Some packages could not be installed. This may mean that you have
fuse3 : Breaks: fuse
vyos-1x : Depends: libvppinfra but it is not installable
Depends: python3-vici (>= 5.7.2) but it is not installable
Depends: python3-vpp-api but it is not installable
Depends: vpp but it is not installable
Depends: vpp-plugin-core but it is not installable
Depends: vpp-plugin-dpdk but it is not installable
vyos-world : Depends: vyatta-cluster but it is not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
P: Saving caches...
