I’ve had container issues with newer 1.4 rollings too. I ran containers fine for a long time with a 1.4 from late 2021 early 2022 without issue, but since trying more recent 1.4 rolling versions they would not start. I just upgraded one of my Vyos nodes to VyOS 1.4-rolling-202302120317, and I am trying to get my containers running again.
With this config:
set container name newrelic-vyos allow-host-networks
set container name newrelic-vyos environment NRIA_LICENSE_KEY value 'XXXXXXXXXXXXXXX'
set container name newrelic-vyos image 'newrelic/infrastructure:latest'
set container name newrelic-vyos volume logging.d destination '/etc/newrelic-infra/logging.d'
set container name newrelic-vyos volume logging.d source '/config/newrelic/logging.d'
set container name newrelic-vyos volume root destination '/host'
set container name newrelic-vyos volume root source '/'
The container repeatedly failed to start with errors like this:
Feb 15 15:20:40 vyos podman[45955]: 2023-02-15 15:20:40.287991932 -0500 EST m=+0.081074531 image pull newrelic/infrastructure:latest
Feb 15 15:20:40 vyos podman[45955]: 2023-02-15 15:20:40.396555336 -0500 EST m=+0.189637635 container create 77a1d44c8c7ed7f38b0ca51bd8f448a01733e88b4350f7fc8a10f144e70144af (image=docker.io/newrelic/infrastructure:latest, name=newrelic-vyos, com.newrelic.description=New Relic Infrastructure agent for monitoring the underlying host., com.newrelic.image.version=1.37.1-rc, com.newrelic.infra-agent.version=1.37.1, [email protected], com.newrelic.nri-docker.version=1.7.5, com.newrelic.nri-flex.version=1.7.0, com.newrelic.nri-prometheus.version=2.17.0, PODMAN_SYSTEMD_UNIT=vyos-container-newrelic-vyos.service)
Feb 15 15:20:40 vyos podman[45955]: Error: OCI runtime error: crun: writing file `/sys/fs/cgroup/cgroup.subtree_control`: Invalid argument
Feb 15 15:20:40 vyos podman[45970]: 2023-02-15 15:20:40.75551926 -0500 EST m=+0.191102848 container cleanup 77a1d44c8c7ed7f38b0ca51bd8f448a01733e88b4350f7fc8a10f144e70144af (image=docker.io/newrelic/infrastructure:latest, name=newrelic-vyos, com.newrelic.description=New Relic Infrastructure agent for monitoring the underlying host., com.newrelic.image.version=1.37.1-rc, com.newrelic.infra-agent.version=1.37.1, [email protected], com.newrelic.nri-docker.version=1.7.5, com.newrelic.nri-flex.version=1.7.0, com.newrelic.nri-prometheus.version=2.17.0, PODMAN_SYSTEMD_UNIT=vyos-container-newrelic-vyos.service)
Feb 15 15:20:41 vyos podman[45980]: time="2023-02-15T15:20:41-05:00" level=warning msg="Switching default driver from overlay2 to the equivalent overlay driver"
Feb 15 15:20:41 vyos podman[45980]: 2023-02-15 15:20:41.141374493 -0500 EST m=+0.129922772 container remove 77a1d44c8c7ed7f38b0ca51bd8f448a01733e88b4350f7fc8a10f144e70144af (image=docker.io/newrelic/infrastructure:latest, name=newrelic-vyos, com.newrelic.nri-docker.version=1.7.5, com.newrelic.nri-flex.version=1.7.0, com.newrelic.nri-prometheus.version=2.17.0, PODMAN_SYSTEMD_UNIT=vyos-container-newrelic-vyos.service, com.newrelic.description=New Relic Infrastructure agent for monitoring the underlying host., com.newrelic.image.version=1.37.1-rc, com.newrelic.infra-agent.version=1.37.1, [email protected])
Feb 15 15:20:41 vyos podman[45980]: 77a1d44c8c7ed7f38b0ca51bd8f448a01733e88b4350f7fc8a10f144e70144af
I’ll try to spin up an older 1.4-rolling to see if I can reproduce a time when it did work
Does this help or is it different? I tried busybox as above and got more errors:
vyos@vyos# set container name busybox allow-host-networks
vyos@vyos# set container name busybox image 'busybox'
vyos@vyos# commit
[ container ]
WARNING: Image "busybox" used in container "busybox" does not exist
locally. Please use "add container image busybox" to add it to the
system! Container "busybox" will not be started!
https://support.vyos.io/
- Make sure you are running the latest version of VyOS available at:
https://vyos.net/get/
- Consult the community forum to see how to handle this issue:
https://forum.vyos.io
- Join us on Slack where our users exchange help and advice:
https://vyos.slack.com
business policy requires it)
Report time: 2023-02-15 16:13:24
Image version: VyOS 1.4-rolling-202302120317
Release train: current
Built by: [email protected]
Built on: Sun 12 Feb 2023 03:17 UTC
Build UUID: 24bdfade-126b-4691-80c6-cab1fdfd73f8
Build commit ID: b00c41e6a547a3
Architecture: x86_64
Boot via: installed image
System type: Xen HVM guest
Hardware vendor: Xen
Hardware model: HVM domU
Hardware S/N: 9955f378-decb-526a-9ff4-47a21a6c0001
Hardware UUID: 9955f378-decb-526a-9ff4-47a21a6c0001
File "/usr/libexec/vyos/conf_mode/container.py", line 402, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/container.py", line 390, in apply
cmd(f'systemctl restart vyos-container-{name}.service')
File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
raise OSError(code, feedback)
PermissionError: [Errno 1] failed to run command: systemctl restart vyos-container-newrelic-vyos.service
returned:
exit code: 1
noteworthy:
cmd 'podman image exists busybox'
returned (out):
returned (err):
time="2023-02-15T16:13:21-05:00" level=warning msg="Switching default driver from overlay2 to the equivalent overlay driver"
cmd 'podman image exists newrelic/infrastructure:latest'
returned (out):
returned (err):
returned (out):
returned (err):
time="2023-02-15T16:13:22-05:00" level=warning msg="Switching default driver from overlay2 to the equivalent overlay driver"
returned (out):
returned (err):
cmd 'systemctl restart vyos-container-newrelic-vyos.service'
returned (out):
returned (err):
Job for vyos-container-newrelic-vyos.service failed because the control process exited with error code.
See "systemctl status vyos-container-newrelic-vyos.service" and "journalctl -xe" for details.
[[container]] failed
Commit failed
