Hi All,
I’m trying to setup HA and config-sync between 2 router over https but the below ERROR shows up when I commit changes, and the configuration does not sync. Unsure if I’m missing something ?!
INFO:vyos_config_sync:Config synchronization: Mode=load, Secondary=192.168.50.27
An error occurred: HTTPSConnectionPool(host='192.168.50.27', port=7443): Max retries exceeded with url: /configure-section (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fdbf9ca8a90>: Failed to establish a new connection: [Errno 111] Connection refused'))
ERROR:vyos_config_sync:An error occurred: HTTPSConnectionPool(host='192.168.50.27', port=7443): Max retries exceeded with url: /configure-section (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fdbf9ca8a90>: Failed to establish a new connection: [Errno 111] Connection refused'))
VyOS Version
vyos@vyos:~$ show version
Version: VyOS 2025.10.30-0020-rolling
Release train: current
Release flavor: generic
Built by: autobuild@vyos.net
Built on: Thu 30 Oct 2025 00:20 UTC
Build UUID: 27f0d9d2-cf34-4ef2-80e7-2fde19861a48
Build commit ID: e8b465297dd33f
Configuration on Router A
set service config-sync mode load
set service config-sync secondary address 192.168.50.27
set service config-sync secondary port 7443
set service config-sync secondary key mykey
set service config-sync section nat
set service config-sync section policy
set service config-sync section service ntp
set service config-sync section qos interface
set service config-sync section qos policy
set service config-sync section interfaces ethernet
set service config-sync section system time-zone
set service config-sync section system option
set service config-sync section system static-host-mapping
set high-availability vrrp group defaultHA interface eth0
set high-availability vrrp group defaultHA hello-source-address 192.168.50.26
set high-availability vrrp group defaultHA peer-address 192.168.50.27
set high-availability vrrp group defaultHA address 192.168.50.25/24 interface eth0
set high-availability vrrp group defaultHA priority 101
set high-availability vrrp group defaultHA track interface eth0
set high-availability vrrp group defaultHA vrid 96
set high-availability vrrp sync-group sync member defaultHA
set high-availability vrrp sync-group sync health-check ping 192.168.50.27
set high-availability vrrp sync-group sync health-check interval 10
set high-availability vrrp sync-group sync health-check failure-count 5
Configuration on Router B
set service https port 7443
set service https listen-address 192.168.50.26
set service https allow-client address 192.168.50.27
set service https api keys id myid key mykey
set high-availability vrrp group defaultHA hello-source-address 192.168.50.27
set high-availability vrrp group defaultHA peer-address 192.168.50.26
set high-availability vrrp group defaultHA priority 100
set high-availability vrrp sync-group sync health-check ping 192.168.50.26
VRRP
vyos@vyos:~$ show vrrp
Name Interface VRID State Priority Last Transition
defaultHA eth0 96 MASTER 101 9m21s
defaultHA eth0 96 BACKUP 100 9m28s
