How we can create an external package for vyos and embed it into vyos iso?
As of now i am making a deb package and placing it into to packages folder and putting it’s entry into scripts/build-submodule scripts, after that only package name is visible in iso but no files are visible in the iso.
How those files will be visible in the iso?
I just share my experience, but please note it may not be recommended by official.
My case is to use nginx
to replace nginx-light
in buildup since I need to use recompiled nginx version with specific parameters, it’s just a little bit more complicated since vyos-1x
depend on nginx-light
, I need to change the dependency and recompile vyos-1x
too. Here is my procedure:
# get source code
git submodule update --init packages/vyos-1x
cd package/vyos-1x
git checkout crux
# note: since project vyos-1x is not sync with project vyos-build, normally, vyos-1x will have newer commits, so for as much as close to release version, we must reset vyos-1x to commit which is prior to release date
git reset --hard <commit prior to reease date>
# modify dependency
vi packages/vyos-1x/debian/control
nginx-light -> nginx
# start build package
docker run --rm -it -v $(pwd):/vyos -w /vyos/packages/vyos-1x \
vyos/vyos-builder \
dpkg-buildpackage -uc -us -tc -b
# deb package will be generated under directory packages/, and build process will take it prior to repository
# Besides, for building right dependency, must replace "nginx-light" with "nginx" in other places
vi data/live-build-config/package-lists/vyos-utils.list.chroot
# The most important thing is to place your own nginx deb package under directory packages/, otherwise, build system just pick default nginx package which also is conflict with our own package
mv nginx_1.15.12-1_jessie_amd64.deb build-vyos/packages/
Then start your build iso.
best regards.
Thank you so much, I tried the same and able to successfully compile custom package…
