Continuing the discussion from Drive filling up?:
After applying the fix @a.srividya recommended and rebooting the system my conntrackd.service is failing to start. Is there a related bug fix for this?
vyos@Vy1:~$ sudo systemctl status conntrackd.service
● conntrackd.service - Conntrack Daemon
Loaded: loaded (/lib/systemd/system/conntrackd.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/conntrackd.service.d
└─override.conf
Active: failed (Result: exit-code) since Sun 2022-11-06 16:47:38 UTC; 7min ago
Docs: man:conntrackd(8)
man:conntrackd.conf(5)
Main PID: 4585 (code=exited, status=1/FAILURE)
Nov 06 16:47:37 Vy1 systemd[1]: Failed to start Conntrack Daemon.
Nov 06 16:47:38 Vy1 systemd[1]: conntrackd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 06 16:47:38 Vy1 systemd[1]: conntrackd.service: Scheduled restart job, restart counter is at 7.
Nov 06 16:47:38 Vy1 systemd[1]: Stopped Conntrack Daemon.
Nov 06 16:47:38 Vy1 systemd[1]: conntrackd.service: Start request repeated too quickly.
Nov 06 16:47:38 Vy1 systemd[1]: conntrackd.service: Failed with result 'exit-code'.
Nov 06 16:47:38 Vy1 systemd[1]: Failed to start Conntrack Daemon.
vyos@Vy1:~$ sudo systemctl restart conntrackd.service
Job for conntrackd.service failed because the control process exited with error code.
See "systemctl status conntrackd.service" and "journalctl -xe" for details.
└─override.conf
Active: failed (Result: exit-code) since Sun 2022-11-06 16:55:08 UTC; 5s ago
Process: 5745 ExecStart=/usr/sbin/conntrackd -C /run/conntrackd/conntrackd.conf (code=exited, status=1/FAILURE)
Main PID: 5745 (code=exited, status=1/FAILURE)
Nov 06 16:55:08 Vy1 systemd[1]: conntrackd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 06 16:55:08 Vy1 systemd[1]: conntrackd.service: Scheduled restart job, restart counter is at 5.
Nov 06 16:55:08 Vy1 systemd[1]: Stopped Conntrack Daemon.
Nov 06 16:55:08 Vy1 systemd[1]: conntrackd.service: Start request repeated too quickly.
Nov 06 16:55:08 Vy1 systemd[1]: conntrackd.service: Failed with result 'exit-code'.
Nov 06 16:55:08 Vy1 systemd[1]: Failed to start Conntrack Daemon.
See additional log output
Nov 6 16:47:27 Vy1 conntrack-tools: vyatta-vrrp-conntracksync invoked at Sun 06 Nov 2022 04:47:27 PM UTC
Nov 6 16:47:27 Vy1 conntrack-tools: Vy1 transitioning to BACKUP state for VRRP sync-group [syncgrp]
Nov 6 16:47:27 Vy1 systemd[1]: Condition check resulted in Conntrack Daemon being skipped.
Nov 6 16:47:27 Vy1 conntrack-tools: ERROR: failed to invoke conntrackd -t
Nov 6 16:47:27 Vy1 conntrack-tools: ERROR: failed to invoke conntrackd -n
Nov 6 16:47:36 Vy1 conntrack-tools: vyatta-vrrp-conntracksync invoked at Sun 06 Nov 2022 04:47:36 PM UTC
Nov 6 16:47:36 Vy1 conntrack-tools: Vy1 transitioning to BACKUP state for VRRP sync-group [syncgrp]
Nov 6 16:47:36 Vy1 systemd[1]: Starting Conntrack Daemon...
Nov 6 16:47:36 Vy1 kernel: [ 147.512935] conntrackd[4517]: segfault at 10 ip 00007f9a95469979 sp 00007ffdfd2f4d40 error 4 in libnetfilter_conntrack.so.3.7.0[7f9a95469000+f000]
Nov 6 16:47:36 Vy1 kernel: [ 147.512959] Code: 41 5c c3 66 0f 1f 44 00 00 48 89 ef e8 70 fa ff ff 48 89 d8 5b 5d 41 5c c3 0f 1f 84 00 00 00 00 00 55 53 48 89 fb 48 83 ec 08 <48> 8b 7f 10 48 85 ff 74 0d e8 f9 f7 ff ff 48 c7 43 10 00 00 00 00
Nov 6 16:47:36 Vy1 systemd[1]: conntrackd.service: Main process exited, code=killed, status=11/SEGV
Nov 6 16:47:36 Vy1 systemd[1]: conntrackd.service: Failed with result 'signal'.
Nov 6 16:47:36 Vy1 systemd[1]: Stopped Conntrack Daemon.
Nov 6 16:47:36 Vy1 conntrackd[4521]: [Sun Nov 6 16:47:36 2022] (pid=4521) [ERROR] lockfile `/var/lock/conntrack.lock' exists, perhaps conntrackd already running?
Nov 6 16:47:36 Vy1 conntrack-tools[4521]: lockfile `/var/lock/conntrack.lock' exists, perhaps conntrackd already running?
Nov 6 16:47:36 Vy1 systemd[1]: conntrackd.service: Main process exited, code=exited, status=1/FAILURE
Nov 6 16:47:36 Vy1 systemd[1]: conntrackd.service: Failed with result 'exit-code'.
Nov 6 16:47:36 Vy1 systemd[1]: Failed to start Conntrack Daemon.
Nov 6 16:47:36 Vy1 conntrack-tools: ERROR: cannot launch conntrackd
Nov 6 16:47:36 Vy1 vyos-configd[552]: Received message: {"type": "node", "data": "/usr/libexec/vyos/conf_mode/ssh.py"}
Nov 6 16:47:36 Vy1 systemd[1]: conntrackd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 6 16:47:36 Vy1 systemd[1]: conntrackd.service: Scheduled restart job, restart counter is at 1.
