When I was installing VyOS-1.2.0 system via Debian-8 Jessie xfce according to “how to build an ISO image” from VyOS User Guide — VyOS rolling release (current), I failed to enter into VyOS configuration mode because of some errors illustrated in below.
------Example: I acted the last step “make iso”, and the machine shows the following fault in the end.
cd vyos-build
./configure
make iso
Some packages could not be installed. This may mean that you have
vyos-world : Depends: mdns-repeater but it is not installable
P: Saving caches…
Reading package lists…
Building dependency tree…
Reading state information…
root@debian:/home/sarami/vyos-build#
I also used the following commands to make sure the fault:
root@debian:/# apt-cache search mdns-repeater
root@debian:/#
root@debian:/# cat /etc/apt/sources.list
deb http://ftp.monash.edu.au/pub/linux/debian/ jessie-updates main contrib non-free
deb Index of /debian jessie main contrib non-free
deb-src Index of /debian jessie main contrib non-free
deb http://security.debian.org/ jessie/updates main
deb-src http://security.debian.org/ jessie/updates main
deb http://www.deb-multimedia.org/ jessie non-free main
deb http://ftp.debian.org/deian/ jessie-updates main
deb cdrom:[Debian GNU/Linux 8.6.0 Jessie - Official amd64 xfce-CD Binary-1 20160917-14:22]/ jessie main
jessie-updates, previously known as ‘volatile’
A network mirror was not selected during install. The following entries
are provided as examples, but you should amend them as appropriate
for your mirror of choice.
deb-src http://ftp.dfbian.org/debian/ jessie-updates main
deb [arch=amd64] Index of linux/debian/ jessie stable
deb-src [arch=amd64] Index of linux/debian/ jessie stable
root@debian:/#
root@debian:/# aptitude install mdns-repeater
Couldn’t find any package whose name or description matched “mdns-repeater”
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 108 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Setting up initramfs-tools (0.120+deb8u2) …
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.120+deb8u2) …
update-initramfs: Generating /boot/initrd.img-3.16.0-4-amd64
root@debian:/home/sarami/vyos-build# ls -al
total 72
drwxr-xr-x 8 root root 4096 Dec 31 11:28 .
drwxr-xr-x 24 sarami sarami 4096 Jan 1 15:31 ..
drwxr-xr-x 8 root root 4096 Jan 1 20:08 build
lrwxrwxrwx 1 root root 20 Dec 31 11:25 configure → scripts/build-config
drwxr-xr-x 4 root root 4096 Dec 31 11:25 data
drwxr-xr-x 8 root root 4096 Dec 31 11:25 .git
-rw-r–r-- 1 root root 50 Dec 31 11:25 .gitignore
-rw-r–r-- 1 root root 5394 Dec 31 11:25 .gitmodules
-rw-r–r-- 1 root root 18002 Dec 31 11:25 LICENSE
-rw-r–r-- 1 root root 1640 Dec 31 11:25 Makefile
drwxr-xr-x 46 root root 4096 Dec 31 11:25 packages
-rw-r–r-- 1 root root 3540 Dec 31 11:25 README.md
drwxr-xr-x 5 root root 4096 Dec 31 11:28 scripts
drwxr-xr-x 2 root root 4096 Dec 31 11:25 tools
Thanks a lot for the help. I am a new learn of VyOS and Linux Debian.
Cheers,
XU
