I am pretty new to VyOS and ipv6. I’m trying to run a couple AD DCs (for “fun”) behind VyOS using a comcast residential gateway. VyOS is set to use the DCs as system-dns and then forward to them on requests (simple). This seems to work great for ipv4.
In the past I’ve had issues with my ipv6 config changing based on the ISP, which borks my DC’s dns+dhcp
configurations when assigning them based on track interface
addresses on my last router (OPNsense).
I had originally thought I needed autoconf
in dhcpv6-options
to get an ipv6 address on WAN, but I finally managed to get a /128
address after much frustration from dhcpv6
by turning off autoconfig
on bond0
(before this, bond0
would not acquire/generate anything ipv6 addresses except a single link-local
address). I also assigned bond0
a MAC address that was the same from my WAN NIC eth1
, which was working with ipv6 previously. I’m not sure if assigning a MAC to bond0
had an effect on acquiring a /128
address on WAN/bond0
Here are the addresses it generated (obscured, but similar):
2001:558:600a:c3:b0b5:dead:beef:6fff/128
(WAN) to 2601:603:beef:dead::/64
(LAN)
The only way I’ve been able to get my DCs to work with ipv6 is when I have a full /128
gateway address to point them at, and then /128
addresses to point at each other for dns. In addition, any gateway/router I’ve used (VyOS or otherwise) doesn’t appear to have an ipv6 connection to the internet unless it’s assigned a /128
address, either.
On the DCs, the /128
addresses always appear to follow the same pattern: The first two hextets are always the same (e.g.) 2601:603:xxx:xxx:
+ link-local
(minus the fe80::
at the start).
Here’s a full example:
2601:603:xxx:xxx:7d2e:beef:dead:4ff/128
– where the 7d2e:beef:dead:4ff === link-local
for that DC (minus fe80::
the xxx:xxx:
part is what appears to change, AFAIK the 2601:603:
at the start always stays the same, even after re-allocation, and of course the link-local
part is always the end of the /128
address.
tl;dr
So I’m wondering, if I want my DCs to be “stable” and have non-changing static ipv6 addresses (questions):
I’ve tried assigning addresses such as 2601:603::1/64
, 2601:603::2/64
in the past and it hasn’t worked, is there something I am missing here?
Is there a way I can configure the DCs so they will use any two “middle” hextets that are generated? Something like:
2601:603::7d2e:beef:dead:4ff/128
If that’s not possible, can I assign the first 4 hextets via eui-64
in VyOS? E.g.: 2601:603:dead:beef::/64
Lastly, is this just the wrong way to go about this?
Should I instead look at setting up NPTv6 (fc00::/64
, etc.)? I’d been avoiding it because it adds another layer of complexity, but I am really not sure if I am doing any of this the “right” way.
Resources:
config
carl@gateway:~$ show configuration
firewall {
all-ping enable
broadcast-ping enable
config-trap disable
ipv6-name OUTSIDE-6-IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
protocol ipv6-icmp
ipv6-name OUTSIDE-6-LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
description "Allow DHCPv6"
destination {
address fe80::/10
port 546
protocol udp
address fe80::/10
rule 21 {
action accept
description "Allow MLD"
protocol icmpv6
address fe80::/10
rule 22 {
action accept
limit {
burst 1
rate 1000/second
protocol icmpv6
ipv6-src-route disable
ip-src-route disable
log-martians enable
name OUTSIDE-IN {
default-action drop
description "Allow traffic from WAN"
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
destination {
address xxx.xxx.0.999
port 00000
protocol tcp_udp
state {
new enable
rule 30 {
action accept
destination {
address xxx.xxx.xxx.1
port 99999
protocol tcp
state {
new enable
name OUTSIDE-LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
bonding bond0 {
address dhcp
address dhcpv6
description WAN
dhcpv6-options {
pd 0 {
interface eth0 {
address 0
sla-id 0
firewall {
in {
name OUTSIDE-IN
local {
name OUTSIDE-LOCAL
ip {
ipv6 {
address {
lacp-rate slow
mac 01:23:45:67:89:49
member {
interface eth1
interface eth2
min-links 0
mode 802.3ad
address xxxx.xxx.xxx.1/24
description LAN
dhcpv6-options {
hw-id 01:23:45:67:89:ea
hw-id 01:23:45:67:89:49
ethernet eth2 {
hw-id 01:23:45:67:89:48
loopback lo {
nat {
destination {
rule 10 {
description "Port forward: https to xxxx.xxx.xxx.0:99999 for Ookla Speed Test"
destination {
port 99999
inbound-interface bond0
protocol tcp
translation {
rule 20 {
description "Port forward: http(s) to xxxx.xxx.xxx.75:00000 for brand X web server"
destination {
port 00000
protocol tcp_udp
translation {
address xxxx.xxx.xxx.75
rule 100 {
outbound-interface bond0
address xxxx.xxx.xxx.0/24
translation {
address masquerade
protocols {
static {
route 0.0.0.0/0 {
interface bond0 {
next-hop xxxx.xxx.xxx.1 {
service {
dns {
dynamic {
interface eth1 {
service blah {
yadda
use-web {
derpider
mdns {
router-advert {
interface eth0 {
ssh {
access-control {
allow {
user carl
ciphers up-yomama
listen-address xxxx.xxx.xxx.1
mac hmac-fuk-yaal
port 1234
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 115200
domain-name man-cave.net
domain-search {
domain man-cave.net
host-name gateway
ipv6 {
login {
user carl {
authentication {
public-keys beepboop {
key ****************
type iamrobot
name-server xxxx.xxx.xxx.2
name-server xxxx.xxx.xxx.3
name-servers-dhcp eth0
ntp {
server xxxx.xxx.xxx.2 {
server xxxx.xxx.xxx.3 {
option {
ctrl-alt-delete reboot
reboot-on-panic
ssh-client {
source-address xxxx.xxx.xxx.1
syslog {
global {
facility all {
level info
facility protocols {
level debug
commands
set firewall broadcast-ping 'enable'
set firewall ipv6-name OUTSIDE-6-IN default-action 'drop'
set firewall ipv6-name OUTSIDE-6-IN rule 10 action 'accept'
set firewall ipv6-name OUTSIDE-6-IN rule 10 state established 'enable'
set firewall ipv6-name OUTSIDE-6-IN rule 10 state related 'enable'
set firewall ipv6-name OUTSIDE-6-IN rule 20 action 'accept'
set firewall ipv6-name OUTSIDE-6-IN rule 20 protocol 'ipv6-icmp'
set firewall ipv6-name OUTSIDE-6-LOCAL default-action 'drop'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 10 action 'accept'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 10 state established 'enable'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 10 state related 'enable'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 20 action 'accept'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 20 description 'Allow DHCPv6'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 20 destination address 'fe80::/10'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 20 destination port '546'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 20 protocol 'udp'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 20 source address 'fe80::/10'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 21 action 'accept'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 21 description 'Allow MLD'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 21 protocol 'icmpv6'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 21 source address 'fe80::/10'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 22 action 'accept'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 22 limit burst '1'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 22 limit rate '1000/second'
set firewall ipv6-name OUTSIDE-6-LOCAL rule 22 protocol 'icmpv6'
set firewall name OUTSIDE-IN default-action 'drop'
set firewall name OUTSIDE-IN description 'Allow traffic from WAN'
set firewall name OUTSIDE-IN rule 10 action 'accept'
set firewall name OUTSIDE-IN rule 10 state established 'enable'
set firewall name OUTSIDE-IN rule 10 state related 'enable'
set firewall name OUTSIDE-IN rule 20 action 'accept'
set firewall name OUTSIDE-IN rule 20 destination address 'xxx.xxx.xxx.75'
set firewall name OUTSIDE-IN rule 20 destination port '00000'
set firewall name OUTSIDE-IN rule 20 protocol 'tcp_udp'
set firewall name OUTSIDE-IN rule 20 state new 'enable'
set firewall name OUTSIDE-IN rule 30 action 'accept'
set firewall name OUTSIDE-IN rule 30 destination address 'xxx.xxx.xxx.1'
set firewall name OUTSIDE-IN rule 30 destination port '99999'
set firewall name OUTSIDE-IN rule 30 protocol 'tcp'
set firewall name OUTSIDE-IN rule 30 state new 'enable'
set firewall name OUTSIDE-LOCAL default-action 'drop'
set firewall name OUTSIDE-LOCAL rule 10 action 'accept'
set firewall name OUTSIDE-LOCAL rule 10 state established 'enable'
set firewall name OUTSIDE-LOCAL rule 10 state related 'enable'
set firewall name OUTSIDE-LOCAL rule 20 action 'accept'
set firewall name OUTSIDE-LOCAL rule 20 icmp type-name 'echo-request'
set firewall name OUTSIDE-LOCAL rule 20 protocol 'icmp'
set firewall name OUTSIDE-LOCAL rule 20 state new 'enable'
set interfaces bonding bond0 address 'dhcp'
set interfaces bonding bond0 address 'dhcpv6'
set interfaces bonding bond0 description 'WAN'
set interfaces bonding bond0 dhcpv6-options pd 0 interface eth0 address '0'
set interfaces bonding bond0 dhcpv6-options pd 0 interface eth0 sla-id '0'
set interfaces bonding bond0 firewall in ipv6-name 'OUTSIDE-6-IN'
set interfaces bonding bond0 firewall in name 'OUTSIDE-IN'
set interfaces bonding bond0 firewall local ipv6-name 'OUTSIDE-6-LOCAL'
set interfaces bonding bond0 firewall local name 'OUTSIDE-LOCAL'
set interfaces bonding bond0 ip
set interfaces bonding bond0 ipv6 address
set interfaces bonding bond0 lacp-rate 'slow'
set interfaces bonding bond0 mac '01:23:45:67:89:49'
set interfaces bonding bond0 member interface 'eth1'
set interfaces bonding bond0 member interface 'eth2'
set interfaces bonding bond0 min-links '0'
set interfaces bonding bond0 mode '802.3ad'
set interfaces ethernet eth0 address 'xxx.xxx.xxx.1/24'
set interfaces ethernet eth0 description 'LAN'
set interfaces ethernet eth0 dhcpv6-options
set interfaces ethernet eth0 hw-id '01:23:45:67:89:ea'
set interfaces ethernet eth1 hw-id '01:23:45:67:89:49'
set interfaces ethernet eth2 hw-id '01:23:45:67:89:48'
set interfaces loopback lo
set nat destination rule 10 description 'Port forward: https to xxx.xxx.xxx.0:99999 for Ookla Speed Test'
set nat destination rule 10 destination port '99999'
set nat destination rule 10 inbound-interface 'bond0'
set nat destination rule 10 protocol 'tcp'
set nat destination rule 10 translation address 'xxx.xxx.xxx.1'
set nat destination rule 20 description 'Port forward: http(s) to xxx.xxx.xxx.75:00000 for Milestone XProtect'
set nat destination rule 20 destination port '00000'
set nat destination rule 20 inbound-interface 'bond0'
set nat destination rule 20 protocol 'tcp_udp'
set nat destination rule 20 translation address 'xxx.xxx.xxx.75'
set nat source rule 100 outbound-interface 'bond0'
set nat source rule 100 source address 'xxx.xxx.xxx.0/24'
set protocols static route 0.0.0.0/0 interface bond0
set protocols static route 0.0.0.0/0 next-hop xxx.xxx.xxx.1
set service mdns
set service router-advert interface eth0
set service ssh access-control allow user 'carl'
set service ssh ciphers 'junkwarden'
set service ssh listen-address 'xxx.xxx.xxx.1'
set service ssh mac 'thegipper'
set service ssh port '22'
set system domain-name 'man-cave.net'
set system domain-search domain 'man-cave.net'
set system host-name 'shakeshack'
set system ipv6
set system login user carl authentication cleartext-password 'murrr'
set system login user carl authentication public-keys ... carl@shakeshack'
set system login user carl authentication public-keys secure type 'abicus'
set system name-server 'xxx.xxx.xxx.2'
set system name-server 'xxx.xxx.xxx.3'
set system name-servers-dhcp 'eth0'
set system ntp server xxx.xxx.xxx.2
set system ntp server xxx.xxx.xxx.3
set system option ctrl-alt-delete 'reboot'
set system option reboot-on-panic
set system option ssh-client source-address 'xxx.xxx.xxx.1'
Thanks much for the help
Edit: I feel kind of dumb for not thinking of this until after writing this ginormous post, but if the link-local
addresses haven’t been changing, why don’t I use those? I know they’re supposed to change every now and again, but I’ve never seen it (at least not on the DCs…)
