Hello everyone,
I need some assistance with a setup that I am trying as a proof of concept. In GNS3, I have a setup where there is a Cisco router, a VyOS router, a switch, and 3 network endpoints: a PC, a phone, and a network appliance.
Networks in use are the following:
Default VLAN1 for the PCs - 192.168.8.0/22
VLAN 100 for the network appliances - 10.100.8.0/29
VLAN 700 for the phones - 172.16.8.0/23
The Cisco router and VyOS router are setup in a VRRP configuration.
There is an acl-list defined on the Cisco router to prevent the network appliances from communicating with other devices on the network. The relevant parts of the config are as follows:
interface FastEthernet0/0.100
description Restricted_Devices_Network
encapsulation dot1Q 100
ip address 10.100.8.5 255.255.255.248
ip access-group Filter_Restricted_Devices in
vrrp 60 description Restricted_Devices_Network
vrrp 60 ip 10.100.8.1
vrrp 60 priority 110
interface FastEthernet0/0.700
encapsulation dot1Q 700
ip address 172.16.8.2 255.255.255.0
vrrp 20 description VoIP
vrrp 20 ip 172.16.8.1
vrrp 20 priority 110
interface FastEthernet0/1
ip address 192.168.8.2 255.255.248.0
duplex auto
speed auto
vrrp 30 description Branch LAN
vrrp 30 ip 192.168.10.16
vrrp 30 priority 110
ip access-list extended Filter_Restricted_Devices
deny ip 10.100.8.0 0.0.0.7 192.168.0.0 0.0.255.255
deny ip 10.100.8.0 0.0.0.7 172.16.0.0 0.0.255.255
permit ip any any
On the VyOS router, the relevant parts of the config are as follows:
set firewall all-ping âenableâ
set firewall broadcast-ping âdisableâ
set firewall config-trap âdisableâ
set firewall group network-group Internal_Networks network â192.168.0.0/16â
set firewall group network-group Internal_Networks network â172.16.0.0/16â
set firewall ipv6-receive-redirects âdisableâ
set firewall ipv6-src-route âdisableâ
set firewall ip-src-route âdisableâ
set firewall log-martians âenableâ
set firewall name Prevented_Networks default-action âacceptâ
set firewall name Prevented_Networks enable-default-log
set firewall name Prevented_Networks rule 5 action ârejectâ
set firewall name Prevented_Networks rule 5 destination group network-group âInternal_Networksâ
set firewall name Prevented_Networks rule 5 log âenableâ
set firewall receive-redirects âdisableâ
set firewall send-redirects âenableâ
set firewall source-validation âdisableâ
set firewall syn-cookies âenableâ
set firewall twa-hazards-protection âdisableâ
set high-availability vrrp group BranchLAN interface âeth2â
set high-availability vrrp group BranchLAN priority â50â
set high-availability vrrp group BranchLAN rfc3768-compatibility
set high-availability vrrp group BranchLAN virtual-address â192.168.10.16/22â
set high-availability vrrp group BranchLAN vrid â30â
set high-availability vrrp group Network_Appliances interface âeth3â
set high-availability vrrp group Network_Appliances priority â50â
set high-availability vrrp group Network_Appliances rfc3768-compatibility
set high-availability vrrp group Network_Appliances virtual-address â10.100.8.1/29â
set high-availability vrrp group Network_Appliances vrid â60â
set high-availability vrrp group VoIP interface âeth1â
set high-availability vrrp group VoIP priority â50â
set high-availability vrrp group VoIP rfc3768-compatibility
set high-availability vrrp group VoIP virtual-address â172.16.8.1/23â
set high-availability vrrp group VoIP vrid â20â
set high-availability vrrp sync-group Main member âFirewallâ
set high-availability vrrp sync-group Main member âBranchLANâ
set high-availability vrrp sync-group Main member âVoIPâ
set high-availability vrrp sync-group Main member âNetwork_Appliancesâ
set interfaces ethernet eth1 address â172.16.8.3/24â
set interfaces ethernet eth1 hw-id â0c:83:ad:78:5a:01â
set interfaces ethernet eth2 address â192.168.8.3/22â
set interfaces ethernet eth2 hw-id â0c:83:ad:78:5a:02â
set interfaces ethernet eth3 address â10.100.8.6/29â
set interfaces ethernet eth3 firewall local name âPrevented_Networksâ
set interfaces ethernet eth3 hw-id â0c:83:ad:78:5a:03â
With the Cisco router on and the active VRRP router, pinging from the net_appliance to an IP address in the default VLAN and the phone VLAN, the pings are administratively prohibited by the access-list.
VPCS> sh ip
IP/MASK : 10.100.8.2/29
GATEWAY : 10.100.8.1
DNS :
MAC : 00:50:79:66:68:0b
LPORT : 20250
RHOST:PORT : 127.0.0.1:20251
MTU: : 1500
VPCS> ping 192.168.10.16
*10.100.8.5 icmp_seq=1 ttl=255 time=5.937 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=2 ttl=255 time=7.071 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=3 ttl=255 time=6.357 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=4 ttl=255 time=6.901 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=5 ttl=255 time=7.913 ms (ICMP type:3, code:13, Communication administratively prohibited)
VPCS> ping 172.16.8.1
*10.100.8.5 icmp_seq=1 ttl=255 time=6.050 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=2 ttl=255 time=7.989 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=3 ttl=255 time=7.953 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=4 ttl=255 time=9.409 ms (ICMP type:3, code:13, Communication administratively prohibited)
*10.100.8.5 icmp_seq=5 ttl=255 time=8.936 ms (ICMP type:3, code:13, Communication administratively prohibited)
VPCS>
Now, when I turn off the Cisco router, the VyOS router becomes the active one, and a ping is done again as before, and this time the pings are allowed through.
VPCS> sh ip
DNS :
MAC : 00:50:79:66:68:14
LPORT : 20266
RHOST:PORT : 127.0.0.1:20267
MTU: : 1500
84 bytes from 192.168.10.16 icmp_seq=1 ttl=64 time=1.532 ms
84 bytes from 192.168.10.16 icmp_seq=2 ttl=64 time=1.271 ms
84 bytes from 192.168.10.16 icmp_seq=3 ttl=64 time=1.454 ms
84 bytes from 192.168.10.16 icmp_seq=4 ttl=64 time=1.315 ms
84 bytes from 192.168.10.16 icmp_seq=5 ttl=64 time=1.258 ms
84 bytes from 172.16.8.1 icmp_seq=1 ttl=64 time=2.693 ms
84 bytes from 172.16.8.1 icmp_seq=2 ttl=64 time=1.473 ms
84 bytes from 172.16.8.1 icmp_seq=3 ttl=64 time=1.393 ms
84 bytes from 172.16.8.1 icmp_seq=4 ttl=64 time=1.464 ms
84 bytes from 172.16.8.1 icmp_seq=5 ttl=64 time=1.325 ms
VPCS>
vyos@vyos:~$ sh firewall name Prevented_Networks
Rulesets Information
IPv4 Firewall âPrevented_Networksâ:
Active on (eth3,LOCAL)
rule action proto packets bytes
5 reject all 0 0
condition - saddr 0.0.0.0/0 daddr 0.0.0.0/0 /* Prevented_Networks-5 */ reject-
with icmp-port-unreachableLOG enabled
10000 accept all 0 0
condition - saddr 0.0.0.0/0 daddr 0.0.0.0/0 LOG enabled
vyos@vyos:~$
Can someone help me out in understanding why the firewall rules in VyOS are not getting triggered/not used?
Thank you!
