I enabled flow-accounting with enable-egress. I have a remote collector from Kentik. There are no egress flows. Only ingress. Is there something else I need to enable?
flow-accounting {
enable-egress
interface eth0
interface eth1
interface eth1.2
netflow {
engine-id 100
server 10.0.3.3 {
port 9995
version 10
syslog-facility all
10.0.3.3 does receive the flows. It’s just every single one says ingress. No matter if I’m uploading or downloading data. Maybe that’s how router interfaces are supposed to work? I setup netflow on the OVS switch that the router is connected through, and it does show ingress/egress traffic.
Now I got what you mean.
Both ingress and egress flows from the interfaces are exported. However, flows sensor cannot determine traffic direction and it marks all the flows as ingress.
