Build vyos 1.4.0-epa2 image with https://github.com/vyos/vyos-vm-images error:
TASK [setup-root-partition : Create a fileystem on EFI partition] ***********************************************************************************************************************************
fatal: [localhost]: FAILED! => {"changed": false, "msg": "Device /dev/loop8\n/dev/loop7p2 not found."}
Even change another vm still got error like this.
Full build log:
ansible-playbook qemu.yml \
-e disk_size=3 \
-e iso_local=tmp/vyos-1.4.0-epa2-amd64.iso \
-e grub_console=serial \
-e cloud_init=true \
-e cloud_init_ds=NoCloud \
-e guest_agent=qemu \
-e enable_ssh=true \
-e custom_files=true
PLAY [qemu] *****************************************************************************************************************************************************************************************
TASK [include_role : {{ roleinputvar }}] ************************************************************************************************************************************************************
TASK [install-packages : Install required packages] *************************************************************************************************************************************************
[WARNING]: Updating cache and auto-installing missing dependency: python3-apt
ok: [localhost]
TASK [mount-iso : Mount ISO] ************************************************************************************************************************************************************************
changed: [localhost]
TASK [mount-iso : Verify checksums of all the files in the ISO image] *******************************************************************************************************************************
ok: [localhost]
TASK [mount-iso : Mount squashfs image from ISO] ****************************************************************************************************************************************************
TASK [get-version : Read version string from iso packages] ******************************************************************************************************************************************
TASK [get-version : Set vyos_version] ***************************************************************************************************************************************************************
ok: [localhost]
TASK [get-version : Debug version string as read from ISO] ******************************************************************************************************************************************
ok: [localhost] => {
"msg": "This is version 1.4.0-epa2"
TASK [create-disk : Create the target disk image] ***************************************************************************************************************************************************
TASK [setup-root-partition : Partition disk (MBR)] **************************************************************************************************************************************************
skipping: [localhost]
TASK [setup-root-partition : Partition disk (GPT)] **************************************************************************************************************************************************
TASK [setup-root-partition : Partition disk (hybrid)] ***********************************************************************************************************************************************
TASK [setup-root-partition : Set partition numbers for next actions (MBR)] **************************************************************************************************************************
TASK [setup-root-partition : Set partition numbers for next actions (GPT)] **************************************************************************************************************************
TASK [setup-root-partition : Set partition numbers for next actions (hybrid)] ***********************************************************************************************************************
ok: [localhost]
TASK [setup-root-partition : Reread partitions from image and mount to loopback] ********************************************************************************************************************
TASK [setup-root-partition : Find loop device path] *************************************************************************************************************************************************
TASK [setup-root-partition : Set vyos_target_drive fact] ********************************************************************************************************************************************
ok: [localhost]
TASK [unmount-pre : Unmount /mnt/inst_root/sys, /mnt/inst_root/proc, /mnt/inst_root/dev] ************************************************************************************************************
ok: [localhost] => (item=sys)
ok: [localhost] => (item=proc)
ok: [localhost] => (item=dev)
TASK [unmount-all : Unmount /mnt/inst_root/boot] ****************************************************************************************************************************************************
ok: [localhost]
ok: [localhost]
TASK [unmount-all : Unmount /mnt/inst_root] *********************************************************************************************************************************************************
ok: [localhost]
TASK [unmount-all : Unmount /mnt/squashfs] **********************************************************************************************************************************************************
ok: [localhost]
TASK [unmount-all : Unmount /mnt/wroot] *************************************************************************************************************************************************************
ok: [localhost]
TASK [unmount-all : Check if the raw image file exists] *********************************************************************************************************************************************
ok: [localhost]
TASK [unmount-all : Remove image partitions] ********************************************************************************************************************************************************
TASK [unmount-all : Remove /dev/mapper entries] *****************************************************************************************************************************************************
changed: [localhost] => (item=loop8p1)
changed: [localhost] => (item=loop8p2)
changed: [localhost] => (item=loop8p3)
TASK [unmount-all : Detach /dev/loop8
/dev/loop7] ***************************************************************************************************************************************************
TASK [unmount-all : Unmount /mnt/cdsquash] **********************************************************************************************************************************************************
TASK [unmount-all : Unmount /mnt/cdrom] *************************************************************************************************************************************************************
PLAY RECAP ******************************************************************************************************************************************************************************************
localhost : ok=26 changed=12 unreachable=0 failed=0 skipped=4 rescued=1 ignored=0
