I am getting below error when exiting out of configure mode.
vyos@vyos# exit
exit
There are stopped jobs.
DEBUG vexit_internal: calling getEditResetEnv() without config session
I ran fg command and it started the ping command. I guess that was the stopped job. So I did Ctrl+C instead of Ctrl+Z and then tried exiting again but got same error.
My other issue is when I am running show command I am getting below error.
vyos@vyos# show proDEBUG vexit_internal: calling getCompletionEnv() without config session
You can execute the command jobs -l , in order to see the running and stopped jobs. When you executed the “fg” command, it brought the only stopped job to the foreground and by entering the Ctrl+C, it has terminated the job gracefully. You need to exit from the config mode and re-enter the mode to clear the message.
vyos@vyos# sh proto
Configuration path: [proto] is not valid
Show failed
vyos@vyos# exit
exit
vyos@vyos:~$ conf
vyos@vyos# sh proto
bgp 71 {
address-family {
ipv4-unicast {
network 172.31.0.0/24 {
